| Posted: Sun Oct 24, 2010 6:57 pm Post subject: Use a violet/UV LED light to check for phosphor wear. |
Got some "new" used tubes that you are thinking about using?
You can't see any wear on them but you know they're used, and you haven't installed them yet?
Well, I've learned that you can illuminate the face of the CRT with a violet/UV LED light, and it will excite the phosphor
faintly, which will reveal phosphor wear that's difficult or even impossible to see with the naked eye and the CRT
not energized.
It can also be helpful in determining the phosphor color of a CRT that's missing its labels. Red phosphor glows
distinctively reddish, blue glows blue, and green glows sort of an off-white color.
Try it. It works pretty well and it's super cheap and easy.
CJ
wkosmann
Joined: 29 Nov 2006 Posts: 387 Location: Middleburg, Virginia
| Posted: Mon Oct 25, 2010 3:28 pm Post subject: |
Please recommend a specific violet/UV LED that one could purchase for this purpose.
_________________ (B)(G)(R) BlendZilla Up Over (R)(G)(B)
| Posted: Mon Oct 25, 2010 3:57 pm Post subject: |
That's pretty cool.
If you haven't got access to that, the other option is to take a photo of the tube face in as even light as possible (no flash!), crop out everything that isn't tube face, and use the equivalent of an auto-level function to enhance the visibility of the wear.
If you want to do that, you need to use as little compression as possible on your photo - ideally none - though, since compression by definition will try to remove data you can't see yourself. Usually even with a JPG you can get an idea what's going on, though.
secstate
| Posted: Mon Oct 25, 2010 4:04 pm Post subject: |
Interesting, I seem to remember that Greg E. stating that LED flashlights also showed wear patterns more easily. A lot of them are shifted towards the blue end of the spectrum so they may be an alternative if you dont' have a blacklight.
| Posted: Tue Oct 26, 2010 1:18 pm Post subject: |
Most any violet LED should work. Or a UV LED, if you can get one.
From what I've seen, using a UV or violet LED to reveal wear patterns is a more sensitive test method than even making a contrast
enhanced photo of the CRT face.
For some reason it seems to be most effective on the blue CRT as well, but it is effective on all colors.
CJ
akajester
| Posted: Tue Oct 26, 2010 1:29 pm Post subject: |
| wkosmann wrote: | | Please recommend a specific violet/UV LED that one could purchase for this purpose. |
If a black light would work, you can either buy a bulb from your local big box store, or Halloween is a good time to get a cheap fluorescent black light. I'm pretty sure mine was under $10.
Dale
| Posted: Tue Oct 26, 2010 2:21 pm Post subject: |
| cmjohnson wrote: | Most any violet LED should work. Or a UV LED, if you can get one.
CJ |
It may be better than Peri's method, but how many people want to spend more than a couple of dollars to determine tube condition.
| Posted: Wed Oct 27, 2010 1:15 pm Post subject: |
I put a 99 cent violet LED into one of those little keychain LED light cases. How much cheaper can it get?
CJ
| Posted: Wed Oct 27, 2010 4:27 pm Post subject: |
Where did you get it?
| Posted: Wed Oct 27, 2010 5:10 pm Post subject: |
I bought several from a guy selling LEDs at a hamfest.
There's also this obscure place called "ebay" where you can get them really, really cheap, too. They may cost more to ship than it costs to buy a handful of them.
CJ
AaronB
Joined: 05 Sep 2007 Posts: 22 Location: Ottawa, Canada
| Posted: Thu Nov 04, 2010 4:20 pm Post subject: |
can't beat 99 cents including shipping and batteries!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300418632901
The downside: based on experience with various cheap Hong Kong based sellers, I can tell you that it will take roughly 2 to 4 weeks to get your package.
