Problems with a Mitsubishi VS-45605 Rear projection
CRTChris
Posted: Wed Oct 20, 2010 4:06 pm    Post subject: Problems with a Mitsubishi VS-45605 Rear projection
Hello all I am looking for a service manual or schematic for a Mitsubishi VS-45605 Right now it just turns on and right back off. Green light on and then back off.
Thank you for all the help in advance.
Jeremy112
Posted: Wed Oct 20, 2010 10:23 pm    Post subject:
Probably would help if you were in the rigth category Smile
You could also try AVS Im sure theres a manual floating around there somewhere for an RPTV Very Happy
CRTChris
Posted: Thu Oct 21, 2010 3:22 am    Post subject:
Thanks I did not know where the Rear projection stuff went.
Posted: Thu Oct 21, 2010 3:24 am    Post subject:
its the power supply, i have a 65 inch that did the same thing.
CRTChris
Posted: Thu Oct 21, 2010 3:38 am    Post subject:
Looks like I got the service manual "Did some searching found out it is a VZ7 Chassis So that will be useful
Rolls-Royce
Posted: Fri Oct 29, 2010 4:33 pm    Post subject:
Blown convergence fuses can also cause the same symptom.
....Royce....
