dturco
| Posted: Wed Oct 20, 2010 2:39 pm Post subject: Need Fast Phosphor explained |
Ok let's say you have some PT 22 fast phosphor tubes. You want to put them in a Marquee 9500 L/C. As I understand it the will put out less light [160Lumens] compared to LCP tubes [260 lumens] but they will be sharper.
I'm confused by this greatly. It may not be explainable in words but less light means less bright to me, so not good. But sharp to me means greater detail and perhaps focus, which sounds better but dimmer and counter-productive in the CRT world as dim as they are already.
So can anyone shed some light on this?
http://www.hulu.com/firefly
dvh99
| Posted: Wed Oct 20, 2010 3:11 pm Post subject: |
i have a pt22 green and i am used to it now, it does output less light but in a dark room that is no problem to me at least.
they are razor sharp though and do not bloom that quick at high contrast levels, they are a great deal sharper then my red lcp.
| Posted: Wed Oct 20, 2010 3:12 pm Post subject: |
Hello
I do not see why fast phosphor (P43) would be any sharper. It has a faster decay rate to enable 96hz frame rates used in stereoscopic display; one does not want left eye info on screen when the right eye info is rendered. P43 has less light output, and a tendency to flicker.
It is not ideal for standard 50hz/60hz video display.
dvh99
| Posted: Wed Oct 20, 2010 3:15 pm Post subject: |
tim i describe what i see and that is a sharper grid with less blooming.
| Posted: Wed Oct 20, 2010 3:41 pm Post subject: |
The concept is pretty simple, Tim. The faster-decay phosphor emits less light - basically it glows less. If it glows less, and for a shorter time, it will appear sharper, but of course at the cost of less light output.
dvh99
| Posted: Wed Oct 20, 2010 3:51 pm Post subject: |
it does not appear sharper it is sharper.
it is not only the phosphor composition but the gun aperture too that is different.
dvh99
| Posted: Wed Oct 20, 2010 4:01 pm Post subject: |
did you buy those pt22s from the buy and sell btw?
dturco
| Posted: Wed Oct 20, 2010 4:07 pm Post subject: |
| dvh99 wrote: | | did you buy those pt22s from the buy and sell btw? |
Yes, I did buy the PT -22's from here. I already have an LUG as a green, very worn, below a 7, but LCP for red and blue. The green is sharper and much more focused but I think that green always is right?
I've been thinking that the mismatched tubes have been making it impossible to get the low IREs correct.
The lower light output has me concerned a bit as I already feel that my machine is to dim. Yet the Green LUG is really bright compared to > R &B.
I might put them in just to find out if it makes a difference, if not, well I can always re-sell them...
dvh99
| Posted: Wed Oct 20, 2010 4:14 pm Post subject: |
those tubes were a steal at 1100 usd.
i bet you will like them for your 3d setup.
dturco
| Posted: Wed Oct 20, 2010 4:18 pm Post subject: |
| dvh99 wrote: | those tubes were a steal at 1100 usd.
i bet you will like them for your 3d setup. |
What 3D set-up?
dvh99
| Posted: Wed Oct 20, 2010 4:21 pm Post subject: |
just guessing
the pinout for the pt22 tubes is exactly the same as the lcp tubes so if you want to replace the green lug with the pt22 you might have to unmod the neckboard although im not entirely sure.
dturco
| Posted: Wed Oct 20, 2010 4:25 pm Post subject: |
| dvh99 wrote: | just guessing
the pinout for the pt22 tubes is exactly the same as the lcp tubes so if you want to replace the green lug with the pt22 you might have to unmod the neckboard although im not entirely sure. |
Or get new TSE designed Neckboards
dturco
| Posted: Wed Oct 20, 2010 4:50 pm Post subject: |
| Tim in Phoenix wrote: | Hello
Don't the Sony G-90's use LUGs, which I thought were p-43? No One has ever said a G-90 is dim.
What with that?
Oooppps,Eismann's replacements are the LUGs and they are not fast phosphor, I was confused.
dvh99
| Posted: Wed Oct 20, 2010 8:47 pm Post subject: |
50hz gives visible flicker 60hz does not.
i have played 12 hrs straight many many times with my ps3 and never noticed anything.
Jeremy112
| Posted: Wed Oct 20, 2010 10:29 pm Post subject: |
Seems the G90 is the ultimate CRT all the way around, especially after all the years of reading about them on here. Where the hells my G90 then?
| Posted: Wed Oct 20, 2010 10:40 pm Post subject: |
| dturco wrote: |
What with that?
Oooppps,Eismann's replacements are the LUGs and they are not fast phosphor, I was confused.  |
Greg, advertises his tubes as being "Simulator Grade CRT's" - and If they are in fact true "Simulator Grade" CRT's, then they would have to be Fast Phosphor greens..
dturco
| Posted: Wed Oct 20, 2010 10:42 pm Post subject: |
| mp20748 wrote: | | dturco wrote: |
What with that?
Greg, advertises his tubes as being "Simulator Grade CRT's" - and If they are in fact true "Simulator Grade" CRT's, then they would have to be Fast Phosphor greens.. |
Great that just confuses me more
