karmat63
| Posted: Tue Oct 19, 2010 5:49 pm Post subject: Black silicone |
I'm looking for RTV black silicone, but can't find in my city GE black RTV. Just a question: all black acetic silicone are equivalent black RTV sealant?
| Posted: Tue Oct 19, 2010 6:43 pm Post subject: |
no, they're not all the same. Stay away from stuff designed for automotive use as it will have additives that are possibly conductive.
zaphod
| Posted: Tue Oct 19, 2010 7:00 pm Post subject: |
what about high-temp muffler sealent? i have some tubes of it here. just curious.
karmat63
| Posted: Tue Oct 19, 2010 7:42 pm Post subject: |
| draganm wrote: | | no, they're not all the same. Stay away from stuff designed for automotive use as it will have additives that are possibly conductive. |
The black silicon I found is used to seal aquariums, so maybe it could work?
psilvest
| Posted: Tue Oct 19, 2010 8:44 pm Post subject: |
is it a problem if it is conductive when used to fix the tube front to the metal frame?
Pier
Ile
| Posted: Tue Oct 19, 2010 10:17 pm Post subject: |
If you are only using it to glue in a tube or the glass to the front of a tube, black elephant snot grade silicon will suffice
_________________ Chip
karmat63
| Posted: Wed Oct 20, 2010 12:15 am Post subject: |
| Nashou66 wrote: | look for the Dow Corning stuff as well, I think Sparky said that is non conductive.
Athanasios |
Farnell Italy has Dow Corning RTV Black silicone. I will order from them.
dvh99
| Posted: Wed Oct 20, 2010 12:38 pm Post subject: |
carmine what is the order number from the silicone at farnell?
| Posted: Mon Nov 01, 2010 10:33 am Post subject: |
From first hand experience, i can assure you any kind of automotive silicone RTV is NOT suitable for use around any HV, as it is all conductive enough to pass that level of electrical pressure.
