scotha
Joined: 27 Mar 2006 Posts: 167 Location: Lilburn, Ga.
| Posted: Sat Oct 16, 2010 3:23 pm Post subject: barco remote |
What is the secret? I simply replaced the battery in my 1208 remote R761664 and now it does not work WTF? When I install the battery the red light comes on and stays on push reset button and nothing happens. Any help would be appreciated. Nevermind I just pushed all buttons multiple times with the battery out and install battery again and it works.
_________________ pj. BD808s, BD801s
| Posted: Sat Oct 16, 2010 5:50 pm Post subject: |
Q: My Barco remote has stopped working, what has happened?
A: If it happened after you changed the battery (or removed the battery), the remote needs to be set-up to control the projector. The Barco remotes can control multiple projectors in a chain using addresses. The projector can be set to respond to a certain address only, using the dip switch's on the controller, what has been set does not matter as all projectors will respond to address 000. On the remote between the Adjust and Standby buttons is a recessed button you can press with a pen, press it and then press the 0 digit on the remote. The remote is now set to projector address 000 and the projector will now respond regardless to the actual address its set to. Alternately you can press the recessed button on the remote while aimed at the projector or screen and the projector will display its address (or bring up the Barco information screen from the menu to view the address), then proceed by pressing those numbers in sequence on the remote i.e. if the projector displays address 025 press 0 then 2 then 5 on the remote and it will be set to control a projector with that address, either way the remote will work again.
