| Posted: Thu Oct 14, 2010 10:28 am Post subject: Sony 09MEX2 V 09MFX3 |
Can anyone explain the difference between the above two Sony tubes. I understand that the 09MEX is from an AC projector and the 09MFX3 is LC and I believe the pin out is the same but I cannot find anything on the tubes resolution etc.
I cannot find a projector on this site that list 09MEX2 tubes unless I missed it.
jantje112
| Posted: Thu Oct 14, 2010 11:04 am Post subject: |
Probably AC tubes from a retrounit. Mentioned before on the site. Aren't they shorter in tube lengt also?
| Posted: Thu Oct 14, 2010 11:06 pm Post subject: |
Does anyone have any idea what projector used the 09MEX2 tube??
tse
| Posted: Fri Oct 15, 2010 12:04 am Post subject: |
They were used in flight simulator (caligraphic) projectors. Maybe never used in other projectors. The neck of the 'MEX is about 1/2" longer than the 09MI (Ampro LC). The bell parts look the same but I can't be totally sure as I don't have a 09MI that is not potted in a housing. The two pinouts are the same (are any Sony tubes different?). They are being replaced with P19LUGs and a pinout adapter in the sim projectors.
Scott
Thomas Jefferson
| Posted: Fri Oct 15, 2010 12:10 am Post subject: |
So there is no problem in using these for HT use if P19LUGs replace them.
tse
| Posted: Fri Oct 15, 2010 12:19 am Post subject: |
My guess is they will work but my only experience with them is firing up an unpotted tube in my Ampro 4200. It worked with the standard neck card and the focus looked good with the standard focus magnet.
Scott
Thomas Jefferson
| Posted: Fri Oct 15, 2010 12:23 am Post subject: |
There doesn't seem to be much information on them anywhere. You wouldn't happen to know what resollution they are capable of or are they in the same league as 09MFX3?
tse
| Posted: Fri Oct 15, 2010 12:39 am Post subject: |
I've never seen the spec sheets. They can't be too much different. If you can get a good set for cheap it would be worth a try.
Scott
Thomas Jefferson
