Marquee 8500 H-Fail
friedwart
Location: Earth, Europe, Germany @ N 51°43'10.73'' E 14°39'05.52''
Posted: Thu Oct 07, 2010 3:01 pm    Post subject: Marquee 8500 H-Fail
Hello,
I have a problem with my M8500. Sometimes the picture disappears with h-fail light on and reappears after one or two seconds, too large and defocused. It then shrinks to the correct size and focus. Sometimes it happened only one time, sometimes a few times behind one another. Another time I can watch a whole movie without any problems. It seems to appear only with horizontal scan frequency of 60kHz and above. I did never have a problem with 720p@50/60/72 or 1080i@(up to)96 which are less than 60kHz horizontal. All caps on the HDM are changed with Panasonic FC series. BTW it is a 2003-08 HDM and I tried a 2003-07 with the same problem. Can anybody help me please? Thanks a lot.
Posted: Thu Oct 07, 2010 3:08 pm    Post subject:
Try to clean the chips on the CLM, especially U7 on the Deflection processor board. If it still persists then try to find another HVPS to test.
friedwart
Posted: Thu Oct 07, 2010 3:45 pm    Post subject:
To cleaning the chips I have to get a removal tool first. I'm glad that I have a complete set of spare boards and power supplies, so I'll try to swap the HVPS (do you really think it could cause by the HVPS?).
Greetings from Germany
Freimut
Posted: Thu Oct 07, 2010 5:26 pm    Post subject:
Hello
It could be arcing in a tube or from the anode wiring (pink cable going to each tube bell.
friedwart
Posted: Thu Oct 07, 2010 6:34 pm    Post subject:
Tim in Phoenix wrote:
Hello
Oh, I don't hope that but I'll check this as soon as I am at home. But why do the failure appears only with higher frequencies?
I'm going to clean the chips and if that doesn't work I'll swap the HVPS.
Freimut
DGP
Posted: Fri Oct 08, 2010 11:20 am    Post subject:
I had exactly the same problem and after properly cleaning the chips and sockets on the CLM its gone.
friedwart
Posted: Thu Oct 14, 2010 9:54 am    Post subject:
I got the removal tool and cleaned all socketed chips. The failure seems to has gone. Thanks a lot to all who helped me.
Freimut
