linux2
| Posted: Fri Oct 01, 2010 5:54 pm Post subject: NEC 9PG+ Problems |
Hi Everyone,
I just upgraded from a Sony 1020q to this nice NEC 9PG+ today. I'm only having a few problems with it. For some reason it is having the following issues:
1.) If I hit "test" or "static" on the remove, to just run some test patterns the units high pitched noise gets louder, and the image seems to stretch up and down and left to right. Then it blanks out (like it reset) and keeps doing it over and over again. Is there something wrong with one of the boards? If so, which one? I would like to get this unit working soon.
2.) The Video input (S-Video and composite) don't work. It seemingly does nothing. I have been able to get it to work with RGBHV input, but seems a bit over kill for my dvd player.
Any ideas would help... I have yet to converge the unit, but I just want to know if I will have to replace anything first.
Thanks!
linux2
| Posted: Fri Oct 01, 2010 8:27 pm Post subject: I think I found the problem |
The problem seems to be that my unit won't work with the svideo or composite input, but I don't know why. It is a 9PG+ unit and I thought it was supposed to have the svideo/composite board... Where is this board located (or what is it actually called) so I can see if I have it or order one for my unit.
Thanks.
Jeremy112
| Posted: Fri Oct 01, 2010 9:03 pm Post subject: |
on the NEC PG Series the only input options available are the ones that are built into the front of the unit.
the S-Video and Composite inputs are right under the RGBHV inputs. you should be able to take your DVD player, hook it up to one of those inputs (If your DVD Player has settings built in to change what signal it outputs such as S-Video or Composite switch it to the one you preffer).
now you MUST have the setup remote for this, if you do not have a setup remote then your SOL. You need to do signal entry using the adjustments button on the remote.
You may come across a screen asking for a password the factory default is: 2580 . Once in the adjustments menu signal entry will be right at the top, select it.
You should see several numbers such as 00 01 02 03 and so on going down the left side of the menu, These are your "inputs". Select a blank area and then follow the menus that follow after that.
On an NEC you have to do signal entry for every input/resolution you use, such as if you have your computer hooked up via RGBHV and then your player with S-Video, you would need to create a new entry for the computer .
I think NEC could have simplified the whole signal deal, but after a while it is pretty easy to use.
Good luck!
CxTurbo
Joined: 13 Oct 2008 Posts: 425 Location: Ontario, Canada
| Posted: Fri Oct 01, 2010 9:17 pm Post subject: |
| Jeremy112 wrote: |
Agreed. Although the NEC's were never marketed by NEC for Home/Consumer use and assumes that you are a factory trained proffesional.
Still does not change that fact that even then it is a pain in the butt..............
Manuals are available here
http://www.curtpalme.com/NECPG_Downloads.shtm
Mechanical setup tips here.
http://www.curtpalme.com/NECPG_MechSetup1.shtm
Incase you are having anymore problems. Helped me a tonne with my Mech setup.
_________________ Paradigm Studio 100's,Studio 20's,CC-690, Paradigm DSP-3400 V1 SUB
Pioneer Elite SC-35 AVR
Pioneer Elite BDP-05FD Bluray
3x Bryston 3B's
URC Complete Control Medius TX-1000 Remote
HTPC (LGA775 Q6600, 8GB DDR2, 7TB Storage) Mediaportal
Lumagen MINI 3D
Moome FULLHD-EXT V2
Audioquest Cable Top to Bottom
9501LC
linux2
| Posted: Fri Oct 01, 2010 9:29 pm Post subject: Doesn't seem to work that way |
Ok, so I did what you said. I hooked up my DVD player. turned it on and plugged the composite video cable into the front of my projector. When creating a new input I set the input source to be "VIDEO". Then when it trys to detect the source it flickers and then says on the "Source Information" screen:
Sync Detect: Auto
G-sync.
Which isn't the composite input. If I plug the composite cable into the "g" of the RGBHV input it spazes out, which tells me it is still trying to use the RGB input.
I'm just lost at how to get this thing to switch over. Is there some hidden menu item or does it just not work on my unit?
linux2
| Posted: Fri Oct 01, 2010 9:36 pm Post subject: |
Also, in the "video mode" area of the "source information" menu it always says "RGB".... not sure why. Is there a way to reset all of the settings on this unit at one time? It is starting to annoy me
Elaine Benes
| Posted: Fri Oct 01, 2010 10:37 pm Post subject: |
You need to have a video board installed in the PG for it to work. *Most* NEC's didn't have the video board installed, in fact, personally, I've owned a lot of NEC's, and only ever had a couple WITH the video board installed.
The video board can be found at the very back of the projector, inside of course, inside the rearmost card cage, I think, in the last slot, if I remember correctly...
Use RGBHV, hook it up to your computer, forget composite/s-video crap.
Also, NEC's MUST have a signal going to them, your internal patterns are ALL synched to the external source, so without a source they'll slam around like crazy trying to synch to a signal that isn't there...
linux2
| Posted: Fri Oct 01, 2010 11:52 pm Post subject: |
You don't have the composite video board installed, which is why it's not seeing the signal. The comp/Svideo board is closest to the back panel on the projector, under that metal shield. I'll bet you'll find a blank slot under that metal shield where it's supposed to be.
linux2
| Posted: Sat Oct 02, 2010 12:05 am Post subject: |
Humm, I see two boards there and no empty slots... perhaps the board is dead or not seated correctly. I'll take them out and look them over and maybe clean them off. The unit is a bit dusty.
Elaine Benes
| Posted: Sat Oct 02, 2010 2:53 am Post subject: |
If the board is there, you have composite video capability, what happens after you hook up your source, then push 1 on the remote, then wait, then try 2, then wait, then try 3(but I think its 2...).
Seriously, ditch composite and s-video altogether. If you have "plain" video sources, you should be after a line doubler AT LEAST, and more appropriately for that projector, a scaler.
| Posted: Sat Oct 02, 2010 4:30 am Post subject: |
To get s-video or composite you press 1 on the remote.
It isnt pointless, its quite well worth having it work in some cases, using s-video i can use my gun-con 45s, the gun-con 2s also work, some after market guns work on the Sega Saturn and also the Scorpion 3 light guns work perfectly. They will not work if you connect to the RGBHV input.
The only time ive seen my picture shrink sideways rapidly like that though was when the H-OUT setting was out of whack, my set was all fubar settings wise on the DEF board.
kschmit2
| Posted: Sat Oct 02, 2010 9:17 am Post subject: |
the Video board is called the V4DEC PWB. I think I may still have one or two of them here. Not entirely sure though.
kschmit2
| Posted: Sat Oct 02, 2010 9:20 am Post subject: |
in order for that switcher to be able to process video or s-video signals it will not only need the respective input cards, but also the same V4DEC PWB along with a special cable to be installed inside the chassis.
I.e. you can either put the V4DEC PWB inside the ISS and route signals through there, or install it inside the PJ and connect your video/s-video signals directly to the PJ and have the processing/decoding done inside the PJ.
Jeremy112
| Posted: Sat Oct 02, 2010 2:03 pm Post subject: |
| Curt Palme wrote: | | You don't have the composite video board installed, which is why it's not seeing the signal. The comp/Svideo board is closest to the back panel on the projector, under that metal shield. I'll bet you'll find a blank slot under that metal shield where it's supposed to be. |
I guess my 9PG Plain got lucky and got that board and the convergence board ,
actually going to pick up a NOS Xtra today to give the 9PG some company
CxTurbo
| Posted: Sat Oct 02, 2010 3:17 pm Post subject: |
My 9000 has the point and video board installed. I guess I got lucky also.......... Unless the plus' were different I thought all the 9's came with the Video board installed........ Or was that Point board.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
| Posted: Sat Oct 02, 2010 3:23 pm Post subject: |
| Jeremy112 wrote: | | Curt Palme wrote: | | You don't have the composite video board installed, which is why it's not seeing the signal. The comp/Svideo board is closest to the back panel on the projector, under that metal shield. I'll bet you'll find a blank slot under that metal shield where it's supposed to be. |
actually going to pick up a NOS Xtra today to give the 9PG some company  |
The 9's were supposed to come with both, but with these sets having gone through multiple owners at this point, who knows what was defective/taken out in the past? It's like expecting a 1993 car to be completely stock at this point...
Jeremy112
| Posted: Sat Oct 02, 2010 3:31 pm Post subject: |
| Curt Palme wrote: | | Jeremy112 wrote: | | Curt Palme wrote: | | You don't have the composite video board installed, which is why it's not seeing the signal. The comp/Svideo board is closest to the back panel on the projector, under that metal shield. I'll bet you'll find a blank slot under that metal shield where it's supposed to be. |
The 9's were supposed to come with both, but with these sets having gone through multiple owners at this point, who knows what was defective/taken out in the past? It's like expecting a 1993 car to be completely stock at this point... |
Too true, a 17 year old machine to still be complete and unmolested is a hard find, but anyway, off to get my NOS PJ
CxTurbo
| Posted: Sat Oct 02, 2010 3:35 pm Post subject: |
Cool, thanks for the confirmation Curt. Just picked up my fourth PG set ( Runco IDP actualy) that you recently rebuilt the boards on 8)
I can relate to the car thing....... See it all day everyday.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
