Jeremy112
| Posted: Sat Sep 18, 2010 7:27 am Post subject: Completely Reset Point convergence on XG1100 |
Yes,... I was playing around a little too much with the point convergence and now my geometry is messed up. I have no idea how to reset the point convergence so if someone can give me a quick heads up?
jarseneau
| Posted: Sat Sep 18, 2010 1:37 pm Post subject: |
Go into the point mode you want to cancel. Hit CTRL+NORMAL, then CANCEL to zero point, LOAD to restore the stored settings (you probably want CANCEL).
_________________ Jerry
MikeEby
| Posted: Sat Sep 18, 2010 4:31 pm Post subject: |
FYI, its not a good idea to use much point convergence on a NEC, it cause banding. I try to get everything as close as I can with the geometry controls. You probably knew that already.
Jeremy112
| Posted: Sun Sep 19, 2010 3:19 pm Post subject: |
| MikeEby wrote: | FYI, its not a good idea to use much point convergence on a NEC, it cause banding. I try to get everything as close as I can with the geometry controls. You probably knew that already.
Mike |
Yep I got that figured out lol, I dont like using anymore point that I have to, but I was in a pinch and needed convergence to be as close as possible for a night (new game came out and had LAN party), noticed the next day that of course the point was off as a result of quickly getting it done.
Jerry, THANK you once again You are a life saver when it comes to these XG's!
