Wyseman
Joined: 16 Apr 2010 Posts: 27 Location: Tolentino (MC) Italy
| Posted: Mon Sep 13, 2010 12:19 pm Post subject: RGBHV cable with joined grounds |
Hello, sorry for posting a stupid question, is it possible to connect all the grounds together in a rgbhv-vga cable?
Thanks everybody, greetings from Italy!
David_Web
| Posted: Mon Sep 13, 2010 12:22 pm Post subject: |
Should be fine I guess.
The outer shell of the BNCs seems to be connected to chassis anyway.
*edit* depending on the cable it might pick up more noise if not shielded properly, but should not make for disaster at least.
_________________ SNR of people are ridiculously low.
Wyseman
| Posted: Mon Sep 13, 2010 3:16 pm Post subject: |
The cable is a mil-spec very very large Philips, 5x74ohm coax with triple external shielding plus the triple shieldin of the single coax itself! Hope it eill work! Thank you!
Greetings from Italy!
