Elaine Benes
| Posted: Sun Sep 12, 2010 10:04 am Post subject: |
Yes, focus first.
Actually, if you're going to do it, electronic astig first, then focus, then setup.
Zero out your static convergence settings, leave green static convergence zeroed, then mechanically match blue and red center to the green. IF you can do this, and NOT use any static convergence on blue and red to match green, you'll have a much more stable convergence. Always work from the center out when doing convergence.
For an NEC, it is useful to use a pattern which comes from the actual source you're setting up...
