HDFury3 to Faroudja DVP-5000
dsc98
Posted: Wed Aug 18, 2010 5:15 pm    Post subject: HDFury3 to Faroudja DVP-5000
I am trying to add HDMI for my G90, DVP-5000 combo.
My source is an HTPC with HDMI output from nVidia 9300 (motherboard) graphics.
The normal computer pass-through works ok, but is only 1600x1200.
Units have been previously calibrated (on HDTV input) for RCS DTC-100 (yes, that old).
When I connect the HDFury3 with GammaX I only get an intermittent picture with scrolling, flickering, and jumping around.
In the few seconds it stays still it looks pretty good.
HDFury3 dips are all ON except 4 (sync pass through).
I am feeding the RGBHV signal to the HDTV input of the Faroudja.
Any hints on how to fix or what to try?
Dave.
Posted: Wed Aug 18, 2010 6:52 pm    Post subject:
The passthrough should work at 1080p, although I haven't tried it.
ARe you using the Fury power supply?
Try connecting the Fury directly to the G90 via the BNC inputs, see if bypassing the Faroudja works.
dsc98
Posted: Thu Aug 19, 2010 11:00 pm    Post subject: HDFury3 to Faroudja DVP-5000
I tried again last night and seems even worse.
Yes, I am using the HDFury3 supply.
-I tried with just HDFury3 (BTW HDFury works ok sending to Sony RPTV via component).
-Still awaiting adaptor to try to G90 directly.
-I also tried tweaking a bit with Powerstrip, but seemed to have no effect.
Most of the time Faroudja says "Invalid HDTV signal".
dsc98
Posted: Tue Aug 31, 2010 6:27 pm    Post subject: HDFury3 to Faroudja DVP-5000 - G90
Help!
I have now tried connecting HDFury3 directly to G90 after getting an adaptor (VGA to female BNC).
I get a jumpy picture with uneven brightness - same as before.
The G90 info display also shows no Vertical sync signal.
I tried setting Clamp to HC with no help - although it seems to revert back to Auto on its own.
I measured the signal outputs; RGB~=.3v, HV~=0.1-0.2volts from the HDFury3.
(NOTE: Measured output of Faroudja is ~3.6volts for HV; doc says 4v)
(NOTE2: Measurements are similar coming directly from the VGA output of HTPC; which works fine when fed to the Faroudja.)
What is the typical voltage for the sync signals? Is the HDFury/HTPC outputting correctly?
I get a stable (but green) image when I set HDFury3 to component output to the G90.
The HDFury3 output works ok connecting to the VGA input of a computer monitor (HP 2169) using RGB.
The HDFury3 also works ok connecting to an older RPTV via component output @1080i.
Thanks for any help or suggestions.
My goal is to add HDMI to the setup and eventually bypass the Faroudja and replace with a Lumagen.
Dave.
drjon
Posted: Mon Mar 28, 2011 5:48 pm    Post subject: Re: HDFury3 to Faroudja DVP-5000 - G90
dsc98 wrote:
Help!
Dave.
Hi Dave, I am facing similar issues with the HDfury3 and Sony G90 - stable and green but only if set to component output. Were you able to solve the issue. Thanks.
