Does an Ampro 4600 require negative sync?
Posted: Tue Aug 17, 2010 11:09 pm    Post subject: Does an Ampro 4600 require negative sync?
Guys!
Trying to help this guy: http://www.avsforum.com/avs-vb/showthread.php?t=1270391
Posted: Tue Aug 17, 2010 11:34 pm    Post subject:
The mighty beastie doesn't care what you feed it. It just works and works and works Wink
Posted: Tue Aug 17, 2010 11:47 pm    Post subject:
Kinda sounds like you Chip... Wink
Posted: Tue Aug 17, 2010 11:51 pm    Post subject:
Yep, it's me.
Make sure he has all the dip-shitz..........oooops I mean dip switches set correctly and he has all the control knobs set to mid point. If he has the shift to far to one side the projector will loose synch and bam, no picture.
