anyone know if another mount fits a g70 edit:GOT 1 !
jeffslife
Posted: Fri Aug 06, 2010 2:23 pm    Post subject: anyone know if another mount fits a g70 edit:GOT 1 !
Does anyone know if another sony ceiling mount like a 12xx or something will hold a sony g70?
pm me or email or post, i have been steadily looking everywhere with no luck.
jeff1slife@yahoo.com
We are ALL job creators !
Posted: Fri Aug 06, 2010 2:58 pm    Post subject:
Nope. The whole mount and bolt pattern is bigger for the G90 and smaller for the 12xx.
You might want to take the drawings and just have somebody fab something up for you... It'll be a little more hassle, but it shouldn't be much (if any) more expensive than finding/buying/shipping a factory mount.
Posted: Fri Aug 06, 2010 3:02 pm    Post subject:
Also do a search on this forum for unistrut.
jeffslife
Posted: Fri Aug 06, 2010 3:04 pm    Post subject:
ok, what about this idea ? What if i made a steel plate and welded it to the mounting plate on the g90 mount or the 12xx mount? then drilled and tapped the correct bolt pattern for the g70?
Ben851
Posted: Fri Aug 06, 2010 3:43 pm    Post subject:
I have used an Electrohome ceiling mount to hoist a Marquee, an NEC PG, and an NEC XG. The bolt patterns are way off, I just ran some unistrut across to get the bolt patterns to line up... i.e. bolt the unistrut to the projector, and then drill new holes into the mount and bolt the unistrut to the mount. It adds 1.5" of height but does the trick just fine..
Ben
jeffslife
Posted: Fri Aug 06, 2010 3:50 pm    Post subject:
Thanks for the info, at least now i can broaden my ceiling mount search to include electrohome (any certain model?)
can i get UNISTRUT at lowes or home depot ?
Posted: Fri Aug 06, 2010 3:55 pm    Post subject:
Give them a call.
http://store.eberliron.com/products/unistrut_parts
Ben851
Posted: Fri Aug 06, 2010 4:12 pm    Post subject:
My mount is a Marquee hoist mount (has a pully system so that I don't have to kill my back lifting the projector up)
Without seeing pictures of the 1272 mount, I would assume you could use the unistrut as an adapter for this mount as well.. You could probably do it with any mount capable of holding up 200lbs...
Ben
jkruger
Posted: Fri Aug 06, 2010 8:14 pm    Post subject:
I have a chief mount that could probably be drilled to fit the G70.
jeffslife
Posted: Fri Aug 06, 2010 8:31 pm    Post subject:
I will get back with you, i will find out by monday if i found one or not. How much you want for it ?
Posted: Sun Aug 08, 2010 10:55 am    Post subject:
It is my hope that you'll hold out for a factory mount for many reasons but they usually start a arguement amonst the Unistrut followers Laughing
