Trick to getting HTPC to look good through Lumagen HDP?
CZ Eddie
Posted: Wed Jul 28, 2010 12:13 pm    Post subject: Trick to getting HTPC to look good through Lumagen HDP?
I hooked up my HDP last night & set it to 720P output resolution.
The HTPC was connected via DVI to HDMI to DVI through my a/v receiver to the HDP.
Text looks awful. Picture is only slightly tolerable. It looked great before I put the HDP in the loop.
Dish Network HD looks great through the HDP.
Posted: Wed Jul 28, 2010 12:41 pm    Post subject:
well what is the resolution output of the PC? Try to match them perfectly or use the passthrough mode. its in the menu , not sure if its in the input section or output section. then you can use the PC timings and settings instead of the HDP . But you should be able to get a great pic from the PC. I used to hook up my macbook to the lumagen all the time , but i used 1080i out from the mac.
CZ Eddie
Posted: Wed Jul 28, 2010 11:31 pm    Post subject:
Thanks, I forgot that even though there is only one input (from my a/v receiver), the HDP will set everything to a different output rez for each signal it gets.
So even though I set the Dish Network HD DVR to 720P, when I turned on my HTPC it set that to 480P automatically.
I've now set it to 720P and it looks normal again. Smile
It's been a few years since I had a VP in my chain!
Posted: Wed Jul 28, 2010 11:34 pm    Post subject:
Cool, its a great little scaler. wait till you use the 11 point greyscale and gamma and each input can have 4 memories. So you can calibrate each source separately now the way you have it set up.
CZ Eddie
Posted: Thu Jul 29, 2010 1:30 am    Post subject:
Thanks Smile
Ideally, there will be just one incoming source. The A/V receiver. Which will act as the switcher for all four of my video devices.
Then I want a 16:9 and a 2.35:1 memory for each video device. Which amounts to a total of eight memories.
Then I want a ninth memory for my Dish DVR for watching sports with all the lights on.
