WTF, Windows 7 refusing to set RGB output > 1600x1200!
Posted: Sun Jul 25, 2010 5:31 pm    Post subject: WTF, Windows 7 refusing to set RGB output > 1600x1200!
So, I just rebuilt my htpc with a clean copy of win7. Upon getting everything installed, I've found that Win7 is flat out f*cking REFUSING to believe that an analog display can do over 1600x1200. Ignoring hidden modes fails - to the extent where changing the mode results in, "You do not have administrative privileges to make this change" followed immediately by "mode invalid". Powerstrip won't override it either.
I had a win7 install before, running 1080i60... so what gives? It won't let me change the monitor type, won't let me override available modes... it's basically just giving me a big f*cking middle finger. What the hell is going on here?! Evil or Very Mad
Posted: Sun Jul 25, 2010 5:52 pm    Post subject:
That's strange. Have you tried writing a custom driver for the display? What is the video card?
greg_mitch
Posted: Sun Jul 25, 2010 5:54 pm    Post subject:
Correct and updated video card driver?
Are you just hooking it up to your projector?
Doesn't moninfo making custom drivers?
AFryia
Posted: Sun Jul 25, 2010 6:05 pm    Post subject: Re: WTF, Windows 7 refusing to set RGB output > 1600x1200
There is a setting for displaying "non-supported" or "non-standard" resolutions. I just can't recall were. That needs to be set.
I'm not familiar with WIN7 though.
Does Win7 handle custom EDID files. I set one up for the PJ at 2000x1600. I'm not sure if the OS is loading it though.
Posted: Sun Jul 25, 2010 6:08 pm    Post subject: Re: WTF, Windows 7 refusing to set RGB output > 1600x1200
I've found that setting, and it gets ignored, unlike before, for some reason.
Drivers are up to date.
I haven't tried making a new EDID since I'm not sure how to go about it yet... I found one that someone made via a search here, so I'll give that a shot first.
akajester
Posted: Sun Jul 25, 2010 7:04 pm    Post subject:
have you tried this? http://www.videoi.com/~pietro/monitor/
Posted: Wed Jul 28, 2010 1:29 am    Post subject:
jesus christ.
I used davemon as above.
That did the trick - I can run different resolutions now. So I was following Mark's thread advice about getting interlaced modes working on an nv card, and that was great, except the default timing has a far too large vertical size. So I decided to use his timings.
And it says my monitor won't support them. The ones with tiny vertical porches work fine. big vertical porch to make it actually work at the right size? NOT f*cking SUPPORTED.
Jesus christ.
akajester
Posted: Wed Jul 28, 2010 4:03 am    Post subject:
Have you tried Ile's timings? Glad to hear you made some progress.
http://curtpalme.com/forum/viewtopic.php?p=230682#230682
dale
Posted: Thu Jul 29, 2010 1:45 am    Post subject:
dale
I'll give it a shot. I'd like to run 1080i72 though.
I've considered hooking the PJ up to the ATI card (in the same computer!), getting the timings right, and transferring them to the nV card. Maybe even use port3 for the ATI and port5 for the nV so I can live switch between them... but if the nV card randomly rejects certain timings that'll be hard.
CZ Eddie
Posted: Thu Jul 29, 2010 3:14 am    Post subject:
Whenever I had a resolution problem, I'd just use the driver for the Sony GDM-FW900 24" widescreen CRT monitor.
It's an XP driver, but it might not hurt to try it in Win7?
I attached the driver to this thread.
XP Driver.zip
 Filename:  XP Driver.zip
 Filesize:  49.27 KB
 Downloaded:  291 Time(s)
Posted: Thu Jul 29, 2010 3:30 am    Post subject:
Eddie is right.
You need a custom monitor driver, the Sony one will work.
If you need a W7 one, use Powerstrip to create one with the settings you want.
I wasted an hour battling this on my W7 build too...
CZ Eddie
Posted: Thu Jul 29, 2010 3:33 am    Post subject: Re: WTF, Windows 7 refusing to set RGB output > 1600x1200
Didn't read the rest of the thread, but I assume you've figured out whether you have admin rights for the account you logged into the machine with?
