AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Tue Jul 20, 2010 11:36 pm Post subject: Blu-Ray choice for CRT Direct Feed |
What Blu-Ray player(s) out there mesh well with CRT (G-70)?
I don't have a video processor so I'm limited to DVI and YPbPr inputs direct to the PJ.
CxTurbo
Joined: 13 Oct 2008 Posts: 425 Location: Ontario, Canada
| Posted: Wed Jul 21, 2010 12:48 am Post subject: |
From what I undestand unless you are HDCP compliant,want 1080p and not have to deal with the image consraint token if/when implemented I would say none. You would have to do a Moome or HDFury hdmi to RGB to take full advantage of even BR @ 1080I/P or you will only get 540P straight to the projector with image constraint active via component or hdmi. If no token is active then you would be looking at max 1080i via hdmi/component if the player supports 1080i via component.
Kinda sucks I know but the Moome EXT product is on sale atm on the main site.
Someone will correct me if I am wrong on this I am sure.
James
_________________ Paradigm Studio 100's,Studio 20's,CC-690, Paradigm DSP-3400 V1 SUB
Pioneer Elite SC-35 AVR
Pioneer Elite BDP-05FD Bluray
3x Bryston 3B's
URC Complete Control Medius TX-1000 Remote
HTPC (LGA775 Q6600, 8GB DDR2, 7TB Storage) Mediaportal
Lumagen MINI 3D
Moome FULLHD-EXT V2
Audioquest Cable Top to Bottom
9501LC
barcoed
Joined: 26 Feb 2008 Posts: 65 Location: Cambridgeshire, UK
| Posted: Wed Jul 21, 2010 8:40 am Post subject: |
I (reluctantly) ditched the Panny BD I bought and failed to successfully integrate and ended up with a PC, which works rather well in the end. On top of Windows (XP at the moment) I use:
AnyDVDHD to remove the need for an HDCP display.
Reclock (to sort the frame timings out).
UDF2.5 driver (not absolutely necessary).
Powestrip (for custom display timings).
TheKMPlayer/MPC-HC/PowerDVD8 (waiting for Slyplayer).
I run the 15 pin analogue out via a decent 7m cable straight into the G70 at 1920x1080p(48/50/60) with no problems.
Still working on the problem or getting the HD sound out to the old receiver (currently making do with SPDIF).
| Posted: Wed Jul 21, 2010 9:17 pm Post subject: |
AFryia,
barcoed's post, Perisoft's rants, and several other recent posts here are excellent examples of why I'm not using an HTPC for BD playback. What a total pain in the ass. And for what? So, you can skip a menu or get a few extra ticks of sharpness? I don't know about you, but I have about 37 things higher on my priority list than spending a bunch of time ironing out BD playback on an HTPC. The hassle factor is just too high at this point. When I go into the theater, I go in to kick back and watch movies. When setting up an HTPC for BD playback is as easy as it is/was for DVD playback, and doesn't require a $500+ computer for solid performance along with an $80 piece of software just for decryption, then I'll get interested.
Personally, I'm using an original PS3 with the old HD Fury on my G70, running 1080p/60, and I couldn't be (much) happier. Could it be a bit sharper with an HTPC or processor with active area scanning? Probably, but it's a beautiful picture and represents very, very little setup and maintenance effort, and ZERO hassle factor. Here's my movie-watching regimen:
Step 1: Insert disc
Step 2: Press play.
Step 3: Raise beer glass and eat popcorn.
No hiccups, no timing issues, video tearing, audio problems, or any other glitches for that matter.
I'd just pick up a Moome EXT-FULLHD v2 for $240, then add the BD player of your choice and that fits your budget. Heck, I've seen current Sony BD players ($150 at BestBuy) going on craigslist for $75-100 like new in box.
AFryia
| Posted: Thu Jul 22, 2010 1:15 am Post subject: |
I'm running the JohnHWMan IFB-DVI-V2 card that's rated to 1080p 60hz and HDCP compliant.
This is a DVI input card. Will HDCP work over DVI? I believe the card is single Link, will that matter?
Anyone out there running this card with a Blu-Ray player?
_________________ My Volt Blog
| Posted: Thu Jul 22, 2010 1:34 am Post subject: |
I don't know the specifics on that card, but if it's truly HDCP-compliant, then yes - you should be good to go with a simple HDMI-DVI cable.
FYI, the original HD Fury used an HDCP-compliant DVI input... Probably about the same vintage chipset as the JohnHWman card, I'd guess.
CxTurbo
| Posted: Thu Jul 22, 2010 2:30 am Post subject: |
| Nashou66 wrote: | If you don't mind the slightly higher cost than other BD players The Oppo 83 is a really nice feature packed player.
Athanasios |
What he said. I would have bought one of those in a heartbeat if they were around when I bought my Elite
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
