betel
Joined: 20 Apr 2006 Posts: 448 Location: Maryville, Tennessee (Just South of Knoxville)
| Posted: Sat May 29, 2010 7:52 pm Post subject: Onkyo TX-NR906 Lossless Surround Issue |
Needs some help guys:
Just installed an OPPO BDP-83 blu-ray player. It came with an AIX Records audio calibration disc. Turns out I am not able to correctly play lossless audio such as Dolby TruHD & DTS-HD on my Onkyo TX-NR906/7.1 speakers connected. When I perform a 7.1 LPCM channel identification test, the receiver only indicates 2 channels and I get output from all channels as each speaker is being tested. Also, the Sub is dead for this test. Compressed 5.1 is fine on the 906 but I bought the receiver for lossless audio.
My previous player was a PS3 Slim. I guess I've been listening to messed up audio the whole time, I always knew something wasn't right.
The 906 has main firmware 1.04 installed and all the DSP files are at the latest level.
Anyone else have a problem playing lossless audio?
| Posted: Sat May 29, 2010 8:51 pm Post subject: |
You have the AVR version of my Integra prepro - the DHC-9.1.
Assuming the Oppo is connected to the via HDMI, then you probably have the Oppo set up to output LPCM, and haven't done the speaker setup.
So, you either need to do the speaker setup on the Oppo (if you want the Oppo to do the decoding of advanced audio), or you need to set the Oppo to output "bitstream" via HDMI (as opposed to "LPCM" as it's probably set now). Personally, I'd set the Oppo up to do bitstream... Might as well let the $2000 piece of gear do the decoding rather than the $500 piece of gear... Not that there's anything wrong with the Oppo.
Oh, and the PS 3 slim was also perfectly capable of outputting bitstream audio via HDMI, too; It just needs to be configured that way just like the Oppo does.
Almost none of these sources come out of the box set up the way most people need them... They're usually set up "lowest common denominator", which in this case is LPCM and 2.0, since that would work with most any system.
betel
| Posted: Sat May 29, 2010 9:35 pm Post subject: |
Thanks for your help SC. Yes, HDMI connection. The 83 can be set to output bitstream, LPCM, or auto. I set it to auto. If I set it on bitstream, I only get the lossy track. The calibration disc has a voice telling you this when you run the check. If I set it for LPCM or auto, I get what I described. I assumed the speaker setup was for when you used the analog outputs of the 83. I'm going to try this test with the PS3. I hope that this is just user error and not the Onkyo.
Do you have the 83 SC? What are you using to play BD?
| Posted: Sat May 29, 2010 11:39 pm Post subject: |
OK, you're right - the Oppo manual says the speaker config is only for the analog outs as you mentioned. Given that, I don't know what the hell is going on. Makes me wonder about the disk or the Oppo. I can't imagine there's a problem with the Onkyo, since it would be a huge problem, and that series of hardware was very popular. I have no problems with LPCM or decoded advanced audio in my Integra.
I guess I (incorrectly) assumed the audio processor in the Oppo could downmix LPCM and that was what was happening... But, obviously not - according to the manual, anyway. That seem strange to me because if you can't down-mix, then lossless discs with 5.1 or 7.1 tracks would sound horrible on a 2-channel system - any vocals and LFE would just be lost. Is that really how it would work?
I'm still using the old PS3 for my source, so my only choice is decoding in the PS3 and sending LPCM - I don't have a choice in the matter.
I'm considering a BDP-80, but haven't decided if it's worth the money to have the DTS-MA or TrueHD lights light up on the Integra and I have other questions (will the PQ really be noticeably better over the PS3?)... Basically, I have decision paralysis because I don't like any of the cheaper stuff, I'm not a big fan of the Oppo manufacturing/aesthetic, and none of the higher-end stuff with a better build/aesthetic/look/feel isn't as good! I guess I want something like the $500 Oppo, but in a Denon or Pioneer case that actually looks like a decent piece of gear (no disrespect to anybody who likes the Oppo - I know it's a great piece of gear, I just hate the look/feel.)
Ron W
| Posted: Sun May 30, 2010 1:34 am Post subject: Re: Onkyo TX-NR906 Lossless Surround Issue |
| betel wrote: | Needs some help guys:
Anyone else have a problem playing lossless audio? |
I have an Oppo BDP83 and there are THREE methods of connection to your AVR to achieve what you are looking for.
1. 7.1 analog outs from the player(player does ALL decoding) in to the 7.1 pass through inputs in to the AVR.(I, personally, don't use this method because bass management options are limited).
2. Bitstream out of the player(via HDMI) in which the AVR is doing the decoding and all soundtracks should light up on the AVRs panel, this is whether it is standard or Blu-Ray discs.
3. LPCM(via HDMI) out of the player(player does all internal decoding)in to the AVR. Many prefer this method since features such as secondary audio are only achievable from BR discs with this hookup. These features are not available via the bitstream method. There really should be no difference in sound between the LPCM and bitstream hookups via HDMI.
I must admit I don't know what you mean by setting the audio to "auto" since my player, in the set-up menu shows, "bitstream", "LPCM" or "Off".
I have the AIX test disc and quite frankly, in my opinion, the permutations and combinations of different channel set-ups just confuses the issue. Remember, the AIX disc is a Blu-Ray disc.
I would set the player to either bitstream or LPCM and do your 7.1 and/or 5.1 channel balance accordingly. Forget about the two-channel test signals. To me it sounds like when you had the original analog connections you may have had the two channel setting on the disc running and that is how the AVR was reading it even though you had a 7.1 hook-up.
Other than bass management settings in your AVR, in the case of connection methods 2 and 3, nothing more has to be done. The ONLY change you should require in the internal setting of the player is setting it to either bitstream or LPCM and make sure the HDMI out is set to |"ON ". These are the simplest methods in that all soundtracks can be played on all types of discs through the AVR.
betel
| Posted: Sun May 30, 2010 1:43 am Post subject: |
PROBLEM SOLVED! YEE-HAW!
"When all else fails, read the directions."
In lossless surround mode, the 906 can support maximum 5.1 channels @ 192KHz sampling. If you connect 7.1 channels you have to limit it to 96KHz. I never realized there was a sampling rate limit. Naturely I set the player up for the highest sampling rate available which confused the receiver. Set the 83's rate to 96KHz and as is well. Whew, that was a close one. If it weren't for the audio calibration disc, I may have not even known there was a problem.
betel
| Posted: Sun May 30, 2010 2:14 am Post subject: |
BTW: The AIX Records audio calibration disc is a worthwhile test disc IMO. The company makes audio recordings in 7.1 high def audio with minimum use of processing. On this disc there are 7 hi-def audio/video presentations. All very impressive.
betel
| Posted: Sun May 30, 2010 4:48 am Post subject: |
| betel wrote: | PROBLEM SOLVED! YEE-HAW!
In lossless surround mode, the 906 can support maximum 5.1 channels @ 192KHz sampling. If you connect 7.1 channels you have to limit it to 96KHz. I never realized there was a sampling rate limit. Naturely I set the player up for the highest sampling rate available which confused the receiver. Set the 83's rate to 96KHz and as is well. Whew, that was a close one. If it weren't for the audio calibration disc, I may have not even known there was a problem. |
According to the 83's user manual, the sampling rate limit only applies to the coax/optical output. Therefore, changing this setting should have not mattered for HDMI. But in fact it did. When I changed this setting from 192Khz --> 96KHz, problem was immediately solved. I'd be curious if anyone else has noticed this. Maybe an error in the user manual.
| Posted: Sun May 30, 2010 2:40 pm Post subject: |
Looking back at your posts, the sample rate limit and resulting incorrect functionality was due an Onkyo limitation, not the Oppo. To quote you from the Onkyo manual:
| Quote: | | In lossless surround mode, the 906 can support maximum 5.1 channels @ 192KHz sampling. If you connect 7.1 channels you have to limit it to 96KHz. I never realized there was a sampling rate limit. |
So, apparently the D/A converters or something else in the audio processing in the Onkyo won't handle more than 6 channels at 192kHz, but will handle 8 at 96kHz. Apparently, it just throw away everything but the two main channels.
Funny - That sort of rings a bell... I think I ran into the same thing with my Integra when I first got it and was playing around with the PS3's audio options. No big deal, since I think most surround mixes are 96/24, anyway.
