BD Player that holds the setting on 1080i????? Please Help
rickp
Posted: Sat May 29, 2010 2:07 pm    Post subject: BD Player that holds the setting on 1080i????? Please Help
My BD player just took a dump so I am looking for another one. The Sherwood I have now is a PITA for setting the 1080i signal, every time I turn it on I have to reset from 1080p. , its way to much drama. Is there a BD player out there with a set and forget for the 1080i signal for say under 300$?????? My NEC XG110 can't quite handle 1080p.
Thanks in advance, Rick.
Posted: Sat May 29, 2010 4:48 pm    Post subject:
Stay away from Samsung,
Sony's remember their settings. Maybe look at the BDP-s360
What do you use for sound? Make sure you get the player you need. If you need 7.1 analog out make sure to get a player with that option. If you are using optical or HDMI for sound you'll save some money
greg_mitch
Posted: Sat May 29, 2010 5:10 pm    Post subject:
My Samsung has been working fine for over a year...
BDP-3600
Also had the LG 370 and it worked fine.
Going from player to HDFury GE, to monoprice switcher, to NEC switcher, to projector.
Posted: Sat May 29, 2010 5:47 pm    Post subject:
How are you connecting the Blu-ray player to your XG?
One option is to add an HDfury3. It has DIP switches to disable 1080p support so that the Blu-ray player will always start at 1080i (max). Very handy for silly Blu-ray players that never remember what resolution you selected and revert to 1080p every time they turn on.
See: www.curtpalme.com/HDfury3.shtm
If you have an older HDfury3, we'll trade it up for you at discount. See: https://www.curtpalme.com/forum_archived/viewtopic.php@t=19153.html
rickp
Posted: Sat May 29, 2010 5:54 pm    Post subject:
Thanks for the response! I am runnoing 7.1 on the sound with an optical to the reciver and HDMI to HD Fury to projector.
So all Sony's remember there settings?? I am sending my wife to town to pick one up right now!
Thanks, Rick.
rickp
Posted: Sat May 29, 2010 6:04 pm    Post subject:
Hi Kal,
I was considering upgrading from the 2 to the 3 just for that reason but alas we are moving and leaving all the equipment in the HT room. Our current BD won't play the most current versions of the Blu-ray disc's and can not be upgraded. , not to mention it won't stay locked to 1080i.
Check out my HT!!!!!
http://www.hometheatershack.com/forums/home-theater-design-construction/16240-lake-martin-theater.html
Posted: Mon Jun 07, 2010 6:56 pm    Post subject:
My Panasonic BD-80 will remain at 1080i or 720P for months on end and it's even un-plugged when the HT isn't in use. I imagine if you left it unplugged for a very long time and drained the internal battery it might revert back to factory defaults though? Great player though, not one hiccup or rejected disc, even played Avatar
rickp
Posted: Mon Jun 07, 2010 10:01 pm    Post subject:
Ok, thanks for all the good advice! I finally hooked up the Sony and imagine that, it stays on 1080! Very cool and my wife can use the HT room now.
Thanks, Rick.
Person99
Posted: Tue Jun 15, 2010 3:30 pm    Post subject: Re: BD Player that holds the setting on 1080i????? Please He
Not to be too much of a smart-ass, but a $50 universal remote will solve this problem! Just have the start up macro wait a second and send the resolution change.
One nice thing about the Lumagen is that you can tell it what EDID you want it to send. My Lumagen tells my LG that it will only accept 1080p/24 and 480i/60. Since 1080p/24 is preferred, as long as the lumagen is turned on first, my LG comes up on 1080p/24. If I pop in a DVD, the LG switches to 480i/60.
