DVI card will not work in XG852
philm
Posted: Mon Apr 12, 2010 2:42 pm    Post subject: DVI card will not work in XG852
I bought the projector with the dvi in it and the guy did say it worked only sometimes. I have verified the card works ok in another XG. Could this be a problem with the daughter card? I am able to make a new entry in slots B and C but no picture???
MikeEby
Posted: Mon Apr 12, 2010 5:34 pm    Post subject:
Does the card show up in the input list menus?
philm
Posted: Mon Apr 12, 2010 6:28 pm    Post subject: XG 852 dvi card
Hi Mike,
Yes it does. When I change from input A to C the only thing happening is the red tube flashing.
philm
Posted: Mon Apr 12, 2010 6:50 pm    Post subject: XG 852 dvi
Hi Mike,
I was just switching between inputs A and C when the pj powered off for a second with FC error code and then switched back on to input A which I have a signal running from a Dish receiver, picture ok on input A.
Before it powered off the only tube lit was red.
Philip
moome
Posted: Sat Apr 24, 2010 4:49 am    Post subject: Re: XG 852 dvi
philm wrote:
Hi Mike,
Philip
check you check the link LED is light up on DVI card?
