how can i make the pitcher wider Barco 800
goodshucken
Posted: Mon Mar 29, 2010 3:26 am    Post subject: how can i make the pitcher wider Barco 800
and also i cant find the dieanglel screws please help
Posted: Mon Mar 29, 2010 4:02 am    Post subject:
Have you read the manual?
http://www.curtpalme.com/docs/BarcoGraphics800_Install.pdf
Also what's a dieanglel screw?
Posted: Mon Mar 29, 2010 4:15 am    Post subject:
Goodshucken, I can tell that you have not fully read the manual yet.
Unless there's someone in Ohio that is familar with Barcos that can come over to run through the unit with you, you REALLY need to read the manual.
We're not trying to be A-holes here, but if you have not read the manual that has all the info in it that you need, you're doing yourself a disservice by asking questions that are completely covered in the manual.
goodshucken
Posted: Mon Mar 29, 2010 4:32 am    Post subject:
i have the original manual i do keep reading it i just get hung up on some things hear and their its all new to me i finally figure out what the diagram for the front table top setup ment i was looking at it for two days ask you all a few times it just was not clear enough to you all it makes perfect sense it took me 2days im trying i got this far so i guise few more days i might have the barco 800 watchable thanks i will only ask for help if i about to throw the thing out the window next time
i will keep reading
Posted: Mon Mar 29, 2010 4:39 am    Post subject:
You didn't answer my question ^
Posted: Mon Mar 29, 2010 4:41 am    Post subject:
The width of the pix is controller by the width control in the geometry menu, the height control is the V size in the same menu
Posted: Mon Mar 29, 2010 4:47 am    Post subject:
Hey Curt, does the Barco 800 have the step by step on screen like the 808s?
Posted: Mon Mar 29, 2010 5:02 am    Post subject:
It does have a guided setup.
Posted: Mon Mar 29, 2010 5:07 am    Post subject:
Ok goodshucken, follow the manual for the mechanical setup ( distance, make sure it's squared to the screen ). Then use the on screen set up and see where that get's you.
goodshucken
Posted: Mon Mar 29, 2010 6:21 pm    Post subject:
sorry i miss spieled it. diagonal screw i found them thanks
thank you for putting me in the right direction i might need some more advice latter tonight im at work now so im going to be reading my manual untill i get home thaNKS
goodshucken
Posted: Mon Mar 29, 2010 6:37 pm    Post subject:
do i use the geometry menu to get 16.9 aspect ?
secstate
Posted: Mon Mar 29, 2010 6:45 pm    Post subject:
Yes use V-size to squeeze the picture down and use H-size to expand until you have achieved a 16:9 ratio. There is no 16:9 stetting per se you have to dial it in. If you don't have a 16:9 screen you will need to measure that you have the proper aspect ratio.
Posted: Mon Mar 29, 2010 6:46 pm    Post subject: Re: how can i make the pitcher wider Barco 800
Steroids?
goodshucken
Posted: Mon Mar 29, 2010 10:24 pm    Post subject:
whear is the geometry menu how can i get their
secstate
Posted: Mon Mar 29, 2010 10:49 pm    Post subject:
I think you really need to read the manual. If you cannot even figure out how to get into the menu you are never going to set it up. Not trying to be an ass but you really seem very confused. Barco's are about the easiest CRT for a beginner but CRTs are not for everybody.
