Need help with ECP focus problem
mtmelvin
Posted: Sat Mar 27, 2010 11:35 pm    Post subject: Need help with ECP focus problem
Greetings. I haven't been here in a while!
A friend has an ECP (3500 I think) that I set up for them. They had me come look at it today and I found that the Green tube is horribly out of focus in the bottom region only (see pic below). This is not an optical problem, the tube face looks exactly like this. Only the Green tube is affected.
I tried adjusting the ES focus pot but and that affects the whole tube (as it should) and not just the affected region.
Does anyone have any ideas about what would cause this or what I should try?
Thanks in advance for your help.
-Mark
Internal test pattern:
Posted: Sat Mar 27, 2010 11:41 pm    Post subject:
Tube fungus:
http://www.curtpalme.com/CLR_Defungus_Sony_Tubes.shtm
LOTREE
Posted: Sun Mar 28, 2010 4:45 am    Post subject:
You can try the CLR/Alcohol method, it may work. I tried flushing one tube with ammonia but it did next to nothing. I took mine apart, surprisingly easy actually, as the fungus was stuck on the glass pretty good. It took several minutes using rubbing alcohol and eye glass cleaner but it worked.
More documentation if you need it:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=20565.html
Posted: Sun Mar 28, 2010 5:31 am    Post subject:
Make sure to replace with a fresh glycol/glycerin mix !
I've had good luck with this stuff but the price has gone up $4 a bottle !
http://www.mcmelectronics.com/product/20-4275
mtmelvin
Posted: Sun Mar 28, 2010 4:19 pm    Post subject:
Thanks for the answers guys. Sounds like fun!!!
-Mark
