Is this HV Boot Toast?
Ironman1965
Posted: Sat Mar 27, 2010 4:38 am    Post subject: Is this HV Boot Toast?
Had a heck of a time getting this puppy off. They must have used half a tube of caulk to glue this on. Is it FUBAR now or can it still be used?
Posted: Sat Mar 27, 2010 4:49 am    Post subject:
If the rubber is in good condition and not brittle it might be fine. Curt might also have a new one.
Posted: Sat Mar 27, 2010 4:52 am    Post subject:
It's better if the cap is intact with no little edges missing.
But unless it has a split right through near to the clip, it should be ok.
Use a touch more Silicone RTV than they did, and make sure it forms a complete ring under the cap.
Ironman1965
Posted: Sat Mar 27, 2010 4:53 am    Post subject:
The Rubber is still soft. If it wasn't I don't think I'd have been able to get it off other than in little pieces. Sad
Ironman1965
Posted: Sat Mar 27, 2010 4:57 am    Post subject:
I could replace it if anyone knows where to get a new one. Could one be salvaged from an old monitor or are they specific to the tube?
Posted: Sat Mar 27, 2010 5:07 am    Post subject:
Clean it up and as said before use lots of silicone. The voltage rating of the cable is very important !
