help with setup baco 800
goodshucken
Posted: Sat Mar 27, 2010 2:35 am    Post subject: help with setup baco 800
i got a barco 800 its set up to hang from the celling how do i change it to be set up for a table top
i have a owners manual but i dont know where to look im a noob
Posted: Sat Mar 27, 2010 3:03 am    Post subject:
Start with this...
http://www.cineversum.com/downloads/tde/BPP/Manuals/Installation/R5975987A_00_Installation.pdf
And this
http://www.curtpalme.com/Barco500_Layout1.shtm
goodshucken
Posted: Sat Mar 27, 2010 3:15 am    Post subject:
ive looked their i just dont understand what im spoopse to do r their screws or what do i turn the lens or some thing
goodshucken
Posted: Sat Mar 27, 2010 4:06 am    Post subject:
i found this is this the way to change the way i want to set up my projector read 4-2
if so please explan what i need to do to put my projector on a table top
whats front table top mean
what does rear table top mean
what does Vertical scan inversion mean
http://www.cineversum.com/downloads/tde/BCI/Manuals/Installation/R5975819_05_Installation.pdf
Posted: Sat Mar 27, 2010 4:22 am    Post subject:
Front table top if sitting on a table pointing at a screen. Not the same with ceiling mounting though... Do some reading !
Posted: Sat Mar 27, 2010 4:27 am    Post subject:
Also check spelling before posting !!! Wink
goodshucken
Posted: Sat Mar 27, 2010 2:49 pm    Post subject:
i will keep on reading but if some one has some advice other than the advice given to me already that would be great
about the spelling i was in a hurry
Posted: Sat Mar 27, 2010 3:29 pm    Post subject:
This might help...
http://moesrealm.com/home-theater/guides/crt-projector-focus-mechanical-aim-basics/
Also buy one of these.
http://www.curtpalme.com/SetupDVD.shtm
Another article...
http://www.isftv.com/Article_Planning_and_Setting_Up.html
Posted: Sat Mar 27, 2010 7:16 pm    Post subject:
Welcome goodshucken. Read the manual from the beginning to the end. Slowly. The Barco is about the best manual out there. If you try and jump around, you'll mess something up. THe H and V reverse scan switches are under the H and V boards, but it also shows that in the manual. THe installation manual is the one you want to read first, then the owner's manual.
Posted: Sat Mar 27, 2010 9:04 pm    Post subject:
Thought I provided this link...
http://www.curtpalme.com/docs/BarcoGraphics800_Install.pdf
RaWsHaRk
Posted: Sat Mar 27, 2010 10:04 pm    Post subject:
dont do anything before reading the manual a few times. but, all You have to do is flip (press) the 3 switches under the boards like curt said.now after that You picture will be screwed up and You have to adjust everything if from the beginning..so read the manual.
Electrohome Marquee 7500.
goodshucken
Posted: Sat Mar 27, 2010 10:40 pm    Post subject:
thanks now im starting to understand i just was not sure on the first steep im going to read more before i try to mess with it tonight
