Shoujiki
Joined: 02 Nov 2007 Posts: 28 Location: Melbourne, Australia
| Posted: Sun Mar 21, 2010 10:09 am Post subject: No HDCP Handshake from Moome IFB-HD in 1272 |
Hey guys,
Got a little issue with the Moome IFB card. It's installed in a 1272, and i believe it's V2, there one before the latest one anyways.
Works fine and all, except, when my bluray player is connected up to my scaler via HDMI, and HDMI out to the PJ, the "curtains close" on my scaler and the green light flashes, telling me theres no HDCP handshake.
Same thing if i directly connect the player to the card, no picture, just black. If i use component out from the bluray player to the scaler and then HDMI out to the PJ, it works perfect (but only up to 1080i, which is what i am using now).
Im actually running 720P to the PJ from the scaler, but it would be nice to be able to have my bluray player hook up to the scaler with HDMI too.
Any suggestions?
_________________ Regards, Kurt.
Melbourne, Australia.
Sony VPH-1272QM
cinema mad
| Posted: Sun Mar 21, 2010 12:31 pm Post subject: |
Hi Kurt,
So you run A DVDO VP30 correct ?
Have you been able to get another HDMI source component to work when connected direct to the Moome cards HDMI input ?..
Cheers..
Shoujiki
| Posted: Sun Mar 21, 2010 12:32 pm Post subject: |
I have a VP20. And i haven't really tried any other device. Not sure if i have any others!
Sony VPH-1272QM
moome
| Posted: Mon Mar 22, 2010 5:40 am Post subject: |
| cinema mad wrote: | Hi Kurt,
Cheers.. |
does anyone use VP30 with IFB card and have problem?
what is the state for DET LED on the IFB V2 plate. does it light up and no blinking?
Shoujiki
| Posted: Mon Mar 22, 2010 11:47 am Post subject: |
Hey moome, just checked the back of the card. All 3 lights are lit up and solid, no blinking. (a red, yellow and green).
However, the light on the VP20 is blinking blue, which according to the manual means, no HDCP signal from TV/Display Device.
Sony VPH-1272QM
cinema mad
| Posted: Mon Mar 22, 2010 2:00 pm Post subject: |
Moome,
I have ran A VP30/ABT102 card with G70/ IFB-DVI and IFB-HD with know issues ..
But I have only run A VP50pro (4:2:2 10bit in/out) with A IFB-HD and V2 Full HD with know Blinking, Works perfect..
Cheers...
moome
| Posted: Tue Mar 23, 2010 4:29 pm Post subject: |
| Shoujiki wrote: | Hey moome, just checked the back of the card. All 3 lights are lit up and solid, no blinking. (a red, yellow and green).
However, the light on the VP20 is blinking blue, which according to the manual means, no HDCP signal from TV/Display Device. |
so it is may a problem on IFB-HD EDID, can you send back for upgrade?
moome
| Posted: Tue Mar 23, 2010 4:30 pm Post subject: |
| cinema mad wrote: | Moome,
Cheers... |
thanks , so there is no problem on IFB FULLHD V2? why not use 444 output?
cinema mad
| Posted: Mon Mar 29, 2010 12:00 pm Post subject: |
Hi Moome,
With my Video components Running 4:2:2 keeps the Video chain as pure as possable..
My Blu-ray player outputs 4:2:2 @12bit through HDMI, the VP50pro Scaler will pass 10bit in/out only for 4:2:2 (not RGB, 444 only 8bit)
so passing 4:2:2 for the entire length of the video chain provides clearly visible improvement such as,
finer gradation , less banding and finer detail..
For 24p Blu-Ray playback with Aspect ratios of 2:35.1/ 2:40.1, I am running custom 1920x817 @ 48Hz(2:2) and 1920x800 @48Hz (2:2) allowing 1:1 maping so no scaling & staying under the 120Mhz bandwidth of my G70 .. 1920x817 @48Hz = 100.260Mhz
Cheers Moome..
moome
| Posted: Tue Apr 06, 2010 4:03 pm Post subject: |
| cinema mad wrote: | Hi Moome,
Cheers Moome.. |
thanks for reply. any Scaler support 444 10bitor 12bit?
cinema mad
| Posted: Mon Apr 12, 2010 2:36 pm Post subject: |
Hi Moome,
No not that I am aware of,
Cheers .. PS how's the EDID chip coming along
