Pin-Cushion Problem NEC 6PG
Vermin
Posted: Tue Mar 16, 2010 9:48 pm    Post subject: Pin-Cushion Problem NEC 6PG
Hi.
I´ve an Problem with my NEC 6PG (6200):
Pictures say more a thousand words:
Nothing found in the Service Manual Sad
Any Idea if there is a Trimpod to adjust a 0 Level of the Pin-Cushion? anywhere?
Or could ist be a weak Resistor?
Posted: Tue Mar 16, 2010 10:06 pm    Post subject:
Normally Pin cushion problems are due to incorrect C drive plug orientation.
Is this a "new" projector to you?
Has it ever been right? Did it fail suddenly?
Or are you setting it up for the first time? (Plug error).
Vermin
Posted: Tue Mar 16, 2010 10:23 pm    Post subject:
ähmm...
I bought the projector used. I don´t know if the PG ever work correctly.
The Problem is on every Input/Entry.
I pluged out and in all Cards. Nothing.
Up to this error, the projector is running without problems.
Posted: Tue Mar 16, 2010 10:30 pm    Post subject:
THe convergence connectors for the V output are on backwards. Mark nailed it.
Vermin
Posted: Tue Mar 16, 2010 10:54 pm    Post subject:
Problem fixed. Thank you.
I´m so stupid Rolling Eyes . I have the same Problem for 3-4 Years with an 9PG.
I must save this Info for the Future.
"there are Convergence Polarity Plugs...there are Convergence Polarity Plugs...there are Convergence Polarity Plugs..."
Posted: Tue Mar 16, 2010 11:10 pm    Post subject:
The first NEC I ever got on trade as a 'high end' set was a PG that came out of a bar. The installation team set the projector up way too far back, and had those connectors reversed. THe pub paid $20K+ for something that never worked right.
