i need help lights blink whats does it mean barco 800
goodshucken
Posted: Mon Mar 15, 2010 11:36 pm    Post subject: i need help lights blink whats does it mean barco 800
ok i bought a broken barco 800 it did not turn on i took the smps to a tv repair shop and now it still dont turn on but now i have red lights that come on 1 light says standby and on the panel under the hood their is two lights on one says stand by the other is blinking and is the processor cycles light what does this mean how do i get my barco to turn on plese any information helps
jkruger
Posted: Tue Mar 16, 2010 12:39 am    Post subject:
You need to stop working on this. Send the SMPS to Curt and get it fixed right instead of making it worse. You may have set yourself up for extra costs to repair it already. Sorry, Seen this happen too many times.
goodshucken
Posted: Tue Mar 16, 2010 1:16 am    Post subject:
thats no fun ive been looken for a new hoobby and this is it i sending it out to get it fix would be the right way but im trying to learn and i wont learn if i have some one else do it.
atlease when i took it in to a tv repair i was able to watch and i was shown a few things that would help me in the future.
i dont have to much invested in it so if i make it worse o well
what do you think the lights mean when they blink where its listed processor cycles
jkruger
Posted: Tue Mar 16, 2010 1:44 am    Post subject:
Have you read and do you understand the manual?
goodshucken
Posted: Tue Mar 16, 2010 1:48 am    Post subject:
no im going to look into that asap thanks
jkruger
Posted: Tue Mar 16, 2010 1:59 am    Post subject:
That might be a good idea. Education is good. Wink
Posted: Tue Mar 16, 2010 2:32 am    Post subject:
I sent you a PM on this forum with a link to the service manual and other info on the 800 but you never read it ?
Check your PMs. Sent it 3 days ago.....
On the top of the menu bar click on private messages.
Wink
goodshucken
Posted: Tue Mar 16, 2010 3:27 am    Post subject:
ok do i need to have some thing hooked up aka dvd player ect for the projector 2 turn on because i plugged in the projector took out the remote and pushed stand by then the fans turn a light turn green ever thing seems to be working but i get no light from the tubes now what
Posted: Tue Mar 16, 2010 4:11 am    Post subject:
Negative or positive sync on the input to the projector and what input are you using on the projector ?
Most DVD players output positive sync.
My 808 only accepts negative sync on input 5. Positive and negative on input 3. Never owned an 800 though.....
You need to do some reading ! Do internal setup menus work ?
Looks like you picked up the PM Thumbs Up
Posted: Tue Mar 16, 2010 5:45 am    Post subject:
This might also help......
http://www.avforums.com/forums/crt-projectors/46096-negative-sync-dreamcast-vga.html
Ile
Posted: Tue Mar 16, 2010 7:40 am    Post subject:
It's normal that processor cycles led is blinking when projector is at standby.
Yes, you need to connect source and turn it on before starting projector.
Useful info
http://www.curtpalme.com/Troubleshooting_Tips_Barco2.shtm
