composr
| Posted: Mon Mar 08, 2010 4:37 pm Post subject: 9PG XTRA red tube problems |
I've had this annoying issue for a little while but it's starting to get worse. The red tube on my PJ will occasionally stop working. The raster is lit up but no picture. It's definitely the tube because if I switch the input leads with another color it behaves the same. The problem exists even in the test patterns. Any ideas? It will usually correct itself but it's happening more frequently now.
Ray
| Posted: Tue Mar 09, 2010 12:45 am Post subject: |
Bad CRT socket
Bad connection at CRT socket
Bad video output card that feeds the red tube.
That's about the possibilities.
composr
| Posted: Wed Mar 10, 2010 6:57 pm Post subject: |
Thanks, Curt. This is the same problem I mentioned to you before. Opening up the area where the neck board lives looks a little daunting, but I'll give it a go.
Ray
composr
| Posted: Wed Mar 10, 2010 7:12 pm Post subject: |
Unless your trip to Boise is in the works, then I'll wait!
Ray
