The use of two different pattern discs.
MrFreedom
Posted: Sat Mar 06, 2010 12:25 am    Post subject: The use of two different pattern discs.
I was wondering if the use of two different pattern discs makes a difference when calibrating a monitor. I just did a re-cal and I found some significant differences in greyscale and color gamut. I used GetGrey first and got good results. I then used the AVS HD 709 disc to re-cal the monitor and got way better greyscale results but not as good color gamut. Can I use the two different readings ie, use the greyscale from AVS and color gamut from GetGrey? Appreciate any help. Thanks.
Endeavor to persevere,
Mr Freedom
www.LetItFlowEnterprises.com
Hitachi 55hdx99 Plasma
Outlaw Audio PrePro 990
Outlaw Audio 7200 Amp
Orb Audio Mod2 7.1 Speaker Sys
DIRECTV HR20700 HD DVR Satellite Receiver
Onkyo DV CP704 DVD 6 Disc Changer
Sony PS3 80G BluRay Game Console
Furman PM Pro Series II Power Conditioner
Blue Jean Cables and Connects
NXG NX-RM505 Learning Remote Control
MrFreedom
Posted: Mon Mar 08, 2010 7:50 am    Post subject:
I did use both discs and improved my color gamut. Getting the better greyscale with the AVS disc made adjusting my color gamut much easier even though I used the GetGrey disc for the gamut. I just ran a basic greyscale cal using AVS HD 709 and then a color gamut cal using GetGrey. Worked out fine. One question though. I'm not being able to save reports in CalMan Color Pro. I hit save but the reports disappear somewhere. Any suggestions? Thanks.
Mr Freedom
