| Posted: Thu Mar 04, 2010 3:15 pm Post subject: |
I've been using a good lens cleaner (from an optician) and disposable cotton tissues -- you can buy them at Whole Foods & probably elsewhere. Spray with lens cleaner first -- enough so it washes stuff off the lens -- to remove as much grime as possible *before* you rub it with ANYthing.
jkruger
| Posted: Thu Mar 04, 2010 3:27 pm Post subject: |
Thanks, I just took an eBay link at random.
The B&L wipes have alcohol infused into the wipes..
| Posted: Thu Mar 04, 2010 4:15 pm Post subject: |
I still say you want to use a spray cleaner FIRST. You want to flush all the nasty scratchy bits off the lens surface BEFORE you touch it with anything.
| Posted: Thu Mar 04, 2010 4:46 pm Post subject: |
There was this formula i got from the "A" site yrs ago... Something about Distilled Water, Alcohol, and a few drops of dish liquid.
I used it and it works great. I'll see if i can find it.
_________________ Follow my blog
| Posted: Thu Mar 04, 2010 4:48 pm Post subject: |
| emdawgz1 wrote: | There was this formula i got from the "A" site yrs ago... Something about Distilled Water, Alcohol, and a few drops of dish liquid.
I used it and it works great. I'll see if i can find it. |
http://www.curtpalme.com/Lens_Cleaning.shtm
| Posted: Thu Mar 04, 2010 4:58 pm Post subject: |
| AnalogRocks wrote: | | emdawgz1 wrote: | There was this formula i got from the "A" site yrs ago... Something about Distilled Water, Alcohol, and a few drops of dish liquid.
http://www.curtpalme.com/Lens_Cleaning.shtm |
roland@b4
| Posted: Thu Mar 04, 2010 5:43 pm Post subject: |
Thats great news just when I thought there was no hope
| Description: |
| Filesize: |
27.49 KB |
| Viewed: |
6080 Time(s) |
| Posted: Thu Mar 04, 2010 6:40 pm Post subject: |
Ok I'll bite. Why are there lenses scattered about your garden?
| Posted: Thu Mar 04, 2010 6:51 pm Post subject: |
Passive recycling!
| Posted: Thu Mar 04, 2010 6:53 pm Post subject: |
He's trying to grow a CRT plant!
| Posted: Fri Mar 05, 2010 1:33 am Post subject: |
I hear the blues are really hard to cultivate, reds aren't an issue.
bbfarmht
Joined: 27 May 2006 Posts: 1273 Location: Where the Mississippi runs east to west!!
| Posted: Fri Mar 05, 2010 2:24 am Post subject: |
and the greens don't last as long as either.
_________________ Adam
Benjamin Franklin
| Posted: Fri Mar 05, 2010 2:44 am Post subject: |
Cliff has pretty good luck with Green !
bbfarmht
| Posted: Fri Mar 05, 2010 2:55 am Post subject: |
| Tom.W wrote: | Cliff has pretty good luck with Green !  |
I hear his keep going up in smoke!!!!!
Benjamin Franklin
rod
Joined: 18 Mar 2006 Posts: 418 Location: Northern Ontario, Canada
| Posted: Fri Mar 05, 2010 4:35 am Post subject: |
I can see a nice sunny day somehow catching those leaves on fire. I have a set of HD8's that I'm looking to do something funky with outside but nothing coming up so far. Getting close to the dumpster as spring nears.
_________________ Rod
| Posted: Fri Mar 05, 2010 4:38 am Post subject: |
Do a camera obscura with them.
| Posted: Fri Mar 05, 2010 4:54 am Post subject: |
Yeah, I keep thinking I should do some kind of science projects with my kids with my set of HD8's... something more constructive than a major ant-burner.
rod
| Posted: Fri Mar 05, 2010 4:55 am Post subject: |
ok. admittedly I had to google that. interesting, but not exactly what I had in mind. I was thinking more in the lines of throwing some intense light thru them and casting images/silhouettes maybe, kinda, sorta. I dunno.
