Weird G70 issue: No video...
Posted: Sat Feb 27, 2010 8:02 am    Post subject: Weird G70 issue: No video...
OK, this isn't my machine we're talking about. It's quest_enterprises' machine, and I'm just trying to help him out.
I went through a few things on the phone with him, and I'm stumped... I'm concerned he has a hardware issue at this point. Here's the deal:
- No external video will display.
- He's tried the RGBHV input, the switcher connector via an Extron interface, and A Moome card in the IFB slot.
- All menus and patterns function properly.
- I went throught the basics on the phone with him: Brightness, contrast, pic mute status...
One weird thing is that he couldn't select the menu option to change sync - it wasn't available. Is that perhaps disabled when the moome card is selected?
So, any ideas? I haven't had a chance to look at the service manual, yet to know which board or connectors to look at. These machines were deinstalled and moved, so there could certainly be a loose card or connector.
I'd like to try to get over and help him in person, but I'd like to have some ideas first to know whether we should have spares or...
That's all I can think of right now. We'll add to this as the questions come up.
Thanks, guys!
Posted: Sat Feb 27, 2010 12:30 pm    Post subject:
This will sound like a really bloody silly suggestion to you im sure, and i certainly mean no disrespect, but is the projector set to the Video or S-Video input instead of RGB?
Posted: Sat Feb 27, 2010 1:54 pm    Post subject:
Also, I forget on the G70, but aren't the sync options only available in service mode? He may need to go into service mode and change sync.
Posted: Sat Feb 27, 2010 3:11 pm    Post subject:
Yep, he knows how to switch inputs, and did so while I was on the phone with him.
Yeah, Craig - he was in service man mode - I had him check hours to verify.
I'm at a loss. I had him check bias and gain to make sure that wasn't backed down...
Troubleshooting over the phone sucks. I think I'm gonna need to just go there and troubleshoot. I wish it wasn't a 2-hour drive each way, but it probably makes sense at this point. He's got two machines, but supposedly they're both doing the same thing.
Posted: Sat Feb 27, 2010 3:26 pm    Post subject:
I'm not sure if this is the same on the G90 and G70, but if a G90 is on certain kinds of systems it will no longer support switching to any inputs other than the one it was set up on. When you remove the G90 from the system it must be reset before it will allow input selection.
EDIT:
Have this guy go into service mode then press the "NORMAL" button on the remote. Then have him press the "SYS SET" button on the remote. After 30 seconds or so a G90 will reset the inputs and all will work as normal. Not sure about the G70, but it's worth a shot. A G90 will place a yellow message on screen while it sets the system. Just let it go until the screen clears the message.
If this is doing the same thing on two projectors he almost certainly has a config or source problem. I doubt he has two G70's with identical failures. Unless maybe it is a bad DC board which seems to have a high failure rate and can cause loss of sync.
Last edited by CIR Engineering on Sat Feb 27, 2010 3:30 pm; edited 2 times in total
Posted: Sat Feb 27, 2010 3:27 pm    Post subject:
Yeah, maybe have him ship you a DC board to try in your G70 before you make the four hour trek.
Posted: Sun Feb 28, 2010 3:01 am    Post subject:
Craig... DC board? That's the convergence board, right? He doesn't seem to having any problem with menus, patterns, OSD, etc...
What are the chances it could be a bad RGB input board (BA board). I still haven't looked at the service manual, but according to Curt's page here:
http://www.curtpalme.com/SonyG70_Layout4.shtm
This board contains all of the video processing, so that a video, component or RGB signal is processed, and the output is fed right to the CRT sockets and tubes.
I'm amazed that Eugene could have gotten two machines with the same bad board, but maybe some numbskull did the same dumb thing to both machines or something.
Man, this one is weird.
quest_enterprises
Posted: Sun Feb 28, 2010 3:09 am    Post subject:
Here is what I did today to trouble shoot,
I reseated the vertical focus board, convergence board, H deflection board, cpu board, main input board and all main power boards.
Same issue with no picture
I swapped the vertical focus board into the other g70.
Same issue with no picture.
All menus and test patterns work.
MikeEby
Posted: Sun Feb 28, 2010 3:16 am    Post subject:
I don't know a G70 at all but don't they have a component input? Could it be set to use that?
quest_enterprises
Posted: Sun Feb 28, 2010 3:22 am    Post subject:
We went through all of the inputs including a moome card. It switches to the different inputs but the picture has sync issues it seems. I just have lines scrolling for a picture.
Posted: Sun Feb 28, 2010 12:17 pm    Post subject:
Forget the projector and check your input cables. I don't know what you have for equipment but try feeding the source to a PC monitor or connect a PC to the projector with a known good break-out cable and try again. Sounds like the problem is external to the projector. Always prove the source before you condem the display!!!
Posted: Sun Feb 28, 2010 2:16 pm    Post subject:
He did that, too Chip. Swapped the same RGBHV cable over to his XG, and it worked fine apparently.
Besides, the same behavior existed between the Moome, RGBHV input, and composite... So, that would have to be 3 completely different input cables bad.
But, the input is obviously functioning in some way. The projector is obviously seeing the signal, as the status changes from "INPUT A - NO INPUT" to just "INPUT A" and it reports the correct fH and FV.
I'm guessing the BA boards are bad. It blows my mind that there could be two machines with the same problem, though
I'd like to know what Curt has to say about, but he's been off the grid for a few days.
Posted: Sun Feb 28, 2010 2:31 pm    Post subject:
Well, if this is a board issue, about the only logical thing it could be right now is the input board. I mean, if OSD's and system messages work and the sync is reported correctly on screen...
Unless you have six bad neck boards or six bad tubes or who knows. You probably need to send some boards to Curt for testing.
Jim Shonk
Posted: Sun Feb 28, 2010 3:06 pm    Post subject:
Remove the moome card and do a factory reset, I had a similar problem and it turned out I was fighting a failed moome
I like to focus Nakid
Posted: Sun Feb 28, 2010 3:07 pm    Post subject:
Ah, that is a good point!
Posted: Sun Feb 28, 2010 5:05 pm    Post subject:
This issue existed before he ordered the moome card. In fact, he picked up the moome card to try a card in the IFB slot other than the switcher card.
Jog my memory... How do you do a factory reset?
Jim Shonk
Posted: Sun Feb 28, 2010 6:02 pm    Post subject:
I wonder if these units were operated with the out board switcher, if so it may be looking for a signal there, go into service mode and cycle the switcher index 1, 2, 3, or 4 hit reset to factory data on all those see if it will try and lock on to a signal afterwords, the fact that both units do this, I am positive it's a setting and not a failure, common since would dictate that. I cant wait t hear what fixes it. (remember reset next to blkg) on the remote. don't forget 0all and switcher/index
Posted: Sun Feb 28, 2010 11:18 pm    Post subject:
Hold down "reset" in service mode for about 15~30 seconds. A prompt will come up for factory or service reset.
The idea of the switcher is what I was thinking as well. Did you have him try the "SYS SET" button while in service mode?
Posted: Mon Mar 01, 2010 12:44 am    Post subject:
Ive seen this exact same thing here,, bad B board (video input), not an uncommon failure but Curt can fix it.
quest_enterprises
Posted: Mon Mar 01, 2010 1:16 am    Post subject:
Evening,
I did the factory reset in service mode. The picture still has the scrolling lines. However, the picture has the color of my desk top which is the projecting source. How do I reset the switcher. Do i go into service mode menu and than 2 inputs and scroll through the switcher there or do it on the switcher on the remote.
