i broke my mini rca connector
dvh99
Posted: Fri Feb 26, 2010 2:03 am    Post subject: i broke my mini rca connector
hi i just took of my vnb and my rca connector but when doing so i ruined the cable, the cable came of but the plug didnt it remained on the vnb.
i have looked everywhere but i just cannot find the cable or just the plug, they are all standard sizes.
anyone any idea where to get those it be much appreciated.
had to take the tube of cause it needed to be filled with the remaining glycol i got in today.
dennis
Posted: Fri Feb 26, 2010 2:07 am    Post subject:
CTP-175-7A
http://www.connect-tech-products.com/index1.php?subtype=Mini%20Phono/RCA%20Plugs&id=16
http://www.connect-tech-products.com/pdfbook/CTP-175-7A.pdf
dvh99
Posted: Fri Feb 26, 2010 2:20 am    Post subject:
thanks.
do you know if there is a minimum to order.
i dont see them going through a lot of hassle selling me 1 connector.
i emailed them already.
dennis
justtaint
Posted: Fri Feb 26, 2010 2:15 pm    Post subject:
deleted - wrong item
Thomas
Sony 1272
Posted: Fri Feb 26, 2010 2:25 pm    Post subject:
justtaint wrote:
ebay item #250572827151
That is for mini coax cable, the connectors are the same size as standard connectors. you need to find 1.7mm diameter pins on the connectors.
Ask if someone has a an extra set of cables.
justtaint
Posted: Fri Feb 26, 2010 2:27 pm    Post subject:
Ah my mistake. Thanks for clarifying.
Thomas
Sony 1272
Ben851
Posted: Fri Feb 26, 2010 2:50 pm    Post subject:
I have some spares that you can have for the cost of shipping from Canada... PM Sent..
Ben
dvh99
Posted: Fri Feb 26, 2010 3:06 pm    Post subject:
i love the fact that electrohome is the only 1 using these mini connectors.
i mailed ben he has some spares.
why in the h... didnt they use proper connectors instead of those fragile clamp ones.
once broken and there is no saving.
Posted: Fri Feb 26, 2010 3:29 pm    Post subject:
You should see the crap Sony used on some of their projectors. I was just talking to Mike Parker about that yesterday. Everyone complains about the Marquee system, but the G90 is worse by a mile.
dvh99
Posted: Fri Feb 26, 2010 3:36 pm    Post subject:
you certainly wouldnt expect to see flimsy connectors on a g90
i have never seen a sony but it must be something, though nothing compared to a marquee of course Smile.
