Marquee 9500 ultra Issue
DGP
Posted: Wed Feb 24, 2010 8:21 am    Post subject: Marquee 9500 ultra Issue
I’m facing a estrange issue with my projector, only in one tube (green). The projector is quite new, from 2004 and has less than 600 hours of use.
I detected that the green tube is always showing a bit of light, even if I use a 0 IRE pattern. I’m not able to turn it completely off by lowering G2 (49 drive 90) or Brightness (50).
Things I already did:
Replace the VNB.
Replace the HDM.
Replace the VIM.
Replace the HV Splitter.
Unplug convergence focus and Stig coils.
Swap video inputs cables from one VNB to the other (Red - Green)
The problem is still there.
Also when I turn the projector off, there is a kind of beam issue, but is not strong enough the burn the tube surface (is almost not visible on screen). The green tube is a P43 type.
Please take a look to the attached video.
Test condition:
0 IRE pattern
Blue and Red tubes are completely dark and green shows a kind of bumping light (not visible on screen) a little bit bigger than the raster size.
Any idea?
DGP
Marquee Issue.rm
Real media video
 Filename:  Marquee Issue.rm
 Filesize:  393.75 KB
 Downloaded:  392 Time(s)
Posted: Wed Feb 24, 2010 1:41 pm    Post subject:
Your green tube is bad, it has contamination in the electron gun, causing the flickering and the dot. Frankly, I'd live with it, but if you want to get rid of the light output, you need to change the tube.
DGP
Posted: Wed Feb 24, 2010 1:54 pm    Post subject:
Thanks Curt for your replay.
I can only see it if I look truth the lens and not on screen, it is visible on screen when I turn the projector off (I see the spot fading out fast). This started to happen some months ago not from the beginning, more or less at the same moment I installed the frankenyokes.
Will this tube die sooner than the other?
It is a shame it is a VDC Marquee build in August 2004.
Posted: Wed Feb 24, 2010 2:27 pm    Post subject:
Try to tap the neck of the green tube while its on. I used a wooden 10cm dowel tapping the neck with the cpc magnets off so i could tap up and down the neck
in that area, do not knock too hard. If it is contamination you'll see a light show inside the tube neck as the contamination burns away, like a small aurora borealis.
DGP
Posted: Wed Feb 24, 2010 2:54 pm    Post subject:
I will try. Just to clarify because my English is not perfect, I should remove the CPC plug again the VNB and turn the projector on, and after that push carefully the glass of the tube neck up/down or right/left with a piece of wood and if I see a light show most probably is contamination.
Will this solve the problem?
Posted: Wed Feb 24, 2010 3:01 pm    Post subject:
No, leave everything installed. Just turn on the projector and tap the magnets with a wooden pole while the projector is running.
You can also try a tube restorer if you know someone who owns one.
This problem might also clear up on its own over time as the contamination (if it is contamination) burns off.
Posted: Wed Feb 24, 2010 3:03 pm    Post subject:
Yes like Craig says, I just like to remove the cpc magnets to be able to see if the tapping of the glass is working or not, you will hear it for sue but some of the final contamination doesn't make a sound but creates a plasma show in the tube neck.
DGP
Posted: Wed Feb 24, 2010 3:07 pm    Post subject:
Thanks for your replies. I will do now and see what happen.
Thanks again,
Diego
DGP
Posted: Wed Feb 24, 2010 5:01 pm    Post subject:
So I did it already and nothing changed. I don’t know if applied the right strength or not long enough, but the picture on screen shakes a little.
I attached a video how I did it.
First time I did this the room was completely dark, just to be able to see if something happen inside the neck.
Diego
Tube contamination.rm
Real Media Video
 Filename:  Tube contamination.rm
 Filesize:  296.25 KB
 Downloaded:  346 Time(s)
Posted: Wed Feb 24, 2010 5:35 pm    Post subject:
Just leave it. If you can't see the light on the screen, you should be fine. The dot isn't near strong enough to burn the phosphor, and you might find that the problem goes away after a while.
I had a 1209s here last night that flickered badly on the red, noticeable on the screen. I ran the set overnight, and this morning it's perfect. THe set was fine when I put it into storage 6 months ago, so I figured the problem would go away overnight, and it did.
Posted: Thu Feb 25, 2010 6:31 am    Post subject:
Diego
Hello. try search some posts about "run in cycles" (that is fearure that barcos has) Similar test picture (flashing 100% white/black screen) can made that tube back to normal..
DVDO VP-50
New hobby, Rally
Ile
Posted: Thu Feb 25, 2010 11:08 am    Post subject:
Phillips test pattern generator have flashing feature.
http://wareseeker.com/download/phillips-pattern-generator-3.11.rar/304089
You can flash black and green screen with 2 sec intervals. You can move and resize flashing window to fill whole screen.
It could take several hours to get crap burned.
Or just use projector normally...
Posted: Thu Feb 25, 2010 3:08 pm    Post subject:
Diego
I think the Barcos actually shut down the tube on each black cycle though.
DGP
Posted: Thu Feb 25, 2010 5:11 pm    Post subject:
I will try with the run in cycle, only flashing a green screen, expanding the raster and defocusing at max. I will leave it some hours, but I want to be around during the run in cycle, just in case the flashing stops for whatever reason, to avoid a nice menu mask on the tube surface.
Thanks for all your replies,
Diego
vespaman
Posted: Sun Mar 07, 2010 1:06 pm    Post subject:
Diego
Did this fix it for you? I had a similar issue with my red beam, and I was convinced it was contaminated (as people has been pointing out), but it turned out to be the HVPS (which I later had to change because it broke down totally) that was making these faint light emissions.
If you have a HVPS to change with, it may be worth a try..
DGP
Posted: Tue Mar 09, 2010 2:44 pm    Post subject:
Diego
The problem is fixed, but I'm not sure if it was contamination or something else. I started the run in circle but after a couple of hours, the projector stopped projecting for some seconds and when the picture came back, the green tube showed some horizontal lines (like a distortion). I replaced the VNB and the problem was not there anymore.
Diego
antorsae
Posted: Fri Mar 12, 2010 7:11 am    Post subject:
You gotta love when that happens!
