dmarnold
Joined: 18 Jan 2010 Posts: 73 Location: St. Louis, MO
| Posted: Sat Feb 20, 2010 3:40 am Post subject: can i (get help with a 6PG Extra) ? |
can i delete all the input settings on my 6pg xtra, shut it down, turn back on connected to a 4:3 source and start over to set-up raster, image settings, etc. ?
_________________ enjoy today, for change is on the way
dmarnold
| Posted: Sat Feb 20, 2010 11:57 pm Post subject: |
70 views yet not a yeah, no or huh?
| Posted: Sun Feb 21, 2010 12:18 am Post subject: |
Can't you just delete all memory blocks with an NEC like with Barcos ?
Elaine Benes
| Posted: Sun Feb 21, 2010 1:26 am Post subject: |
In my experience, yes, you can do that without issue. Doug Baisey used to caution against things like that because a factory set NEC had factory setup lines stored which other memories would be built on, BUT, some NEC's I'd had, had been so screwed up, they wouldn't really do anything properly till I got rid of all the screwed up previously stored memories...
So, do it with caution, I've had some success doing it, but there is reason for caution...
I've done an Eeprom Init too in order to just wipe the whole memory, it solved the issue I was having without wrecking the projector, but it was a risk I was willing to take as the projector wasn't working properly anyway and if the Eeprom Init didn't fix it, it wouldn't have been any worse off...
| Posted: Sun Feb 21, 2010 1:37 am Post subject: |
Anybody heard from Doug lately ?
jarseneau
| Posted: Sun Feb 21, 2010 2:48 am Post subject: |
| dmarnold wrote: | 70 views yet not a yeah, no or huh?  |
Actually a fairly predectable result when the subject is 'can I?' and nothing more specific You get a lot of looks simply out of curiosity.
For the NEC, I'm pretty sure you also need to create a 'Default' memory that has all the settings set to their mid position. To accomplish that you need create an input or use an existing input and change all settings to mid, save it as the default input, then delete the input (and all others) from the input list.
_________________ Jerry
wallace123456
Joined: 14 Aug 2006 Posts: 2236 Location: Northwest VA area
| Posted: Sun Feb 21, 2010 3:16 am Post subject: Re: can i (get help with a 6PG Extra) ? |
| dmarnold wrote: | | can i delete all the input settings on my 6pg xtra, shut it down, turn back on connected to a 4:3 source and start over to set-up raster, image settings, etc. ? |
I'm sure you can.
wallace
_________________ Life Is Good, But BBQ Is Better! BBQ Competition Team
| Posted: Sun Feb 21, 2010 3:19 am Post subject: |
| Tom.W wrote: | | Anybody heard from Doug lately ? |
When I was in LA on October, no one had heard from him in months. I'll give him a call tomorrow to see if his number is still active.
Elaine Benes
| Posted: Sun Feb 21, 2010 3:26 am Post subject: |
| Tom.W wrote: | | Can't you just delete all memory blocks with an NEC like with Barcos ? |
No, not like a Barco at all really...
What you can do is do a new Signal Entry, choose "Temporary" as the initial data, finish it out, save it, then go to the top menu line for each aspect of the new entry and do a CTL+Normal, choose Cancel and confirm that. If you do it for Alignment, Convergence, Focus, Picture you will reset ALL aspects of that new memory to null, which in the case of an NEC is the "0" setting. Its a good way to start from scratch. On Xtra's and XG's I usually null out everything line by line so I don't have to reset the Phase or Line Distortion if those aspects look good. I find setting those things up quite difficult to get looking good...
dmarnold
| Posted: Tue Feb 23, 2010 4:13 am Post subject: THANKS GUYS |
Thank you all. will try the suggestions.
