gan
Joined: 10 Feb 2007 Posts: 36 Location: Geraldton Western Australia
| Posted: Fri Feb 19, 2010 11:26 am Post subject: unusual behaviour? |
ok this is about my remote control issues,so mayhap in the wrong area but involves nearly everything.
i used the panel on the 808s to do all the adjustments needed to get a watchable picture,Then purchased a Barco remote from a member on this forum to do all the fine tuning.Then programmed a 525 universal remote to take over all activities as it were.Now the Barco remote which previously had all functions operational was no longer working at all.I swapped batteries several times to see if that may have been the problem even though the remote appeared to be sending a signal.
Now i have found that after trying to do some more fine tuning that the hard wired panel on the pj does not respond at all either!
Is there a fuse or something like that would render the pj unable to recieve a signal?
Any help on this matter is greatly appreciated
All things considered it seems as though my Barco has been hijacked.
Ile
| Posted: Fri Feb 19, 2010 1:10 pm Post subject: |
You probably know that it's needed to learn projector address for Barco remote after battery swap by pressing recessed button and number zero. Zero works with all addresses set by controller board dip switches.
If projector is not responding to any remote/hard wired remote, problem could be lack of some voltage from smps or problem in controller board.
If you get projector running, is there all green leds on in G2 board?
http://www.curtpalme.com/Barco808_Layout7.shtm
