Yaphet Guest
| Posted: Tue Feb 16, 2010 3:14 pm Post subject: Saving Marquee 8500 picture settings |
For some reason My Marquee 8500 will not save and store my display settings. The size, contrast and brightness will be correct but the convergence will always be off a bit. It seems as if I always have to converge it just a bit. Is this normal? Is there a way it can save it just as I left it so I don't have to converge it every time I turn the projector back on? Thanks
| Posted: Tue Feb 16, 2010 3:27 pm Post subject: |
| Nashou66 wrote: | Hi, first off never do convergence on cold PJ. Let it warm up at least 15 minutes. Do your convergence then lock the memory Recall/Channel. Also make sure you have ASR off. it sometimes does not work right.
next time you turn the PJ on, Convergence will be off till it warms up and should fall into place.
| and if you o all that and it still drifts then it might be time to re-build the board
| Posted: Tue Feb 16, 2010 4:07 pm Post subject: |
| draganm wrote: | | Nashou66 wrote: | Hi, first off never do convergence on cold PJ. Let it warm up at least 15 minutes. Do your convergence then lock the memory Recall/Channel. Also make sure you have ASR off. it sometimes does not work right.
| and if you o all that and it still drifts then it might be time to re-build the board |
I was saving that for you buddy
lol
PS took package to UPS, 50lbs should be there friday.
Yaphet Guest
| Posted: Tue Feb 16, 2010 8:49 pm Post subject: |
Yea, I should have known to let it warm up. NEWBEE! I do need to get all the mods done to my baby, thats comming soon! Thanks!
