9500lc focus board
dvh99
Posted: Wed Feb 03, 2010 1:53 pm    Post subject: 9500lc focus board
hi does anyone know what the black box on my focus board is used for?
here are some pics
 Filesize:  56.79 KB
 Viewed:  6014 Time(s)
 Filesize:  154.19 KB
 Filesize:  109.6 KB
 Filesize:  135.37 KB
Posted: Wed Feb 03, 2010 2:03 pm    Post subject:
It changes the amount of pin and key range. I've seen this before somewhere, I believe it was used for curved screens or simulator use.
Sparky015
Posted: Wed Feb 03, 2010 2:23 pm    Post subject:
Is this also what an ultra board looks like? I have never been graced by the presence of a Marquee Ultra Smile
~Paul
Posted: Wed Feb 03, 2010 2:27 pm    Post subject:
Yes, that's for use in projectors that are to be used in a dome. It extends the range of adjustment of foucs and geometry.
CJ
Sparky015
Posted: Wed Feb 03, 2010 2:29 pm    Post subject:
Your own mini-IMAX. Now that would be cool!
~Paul
dvh99
Posted: Wed Feb 03, 2010 2:33 pm    Post subject:
well thats nice but i have to to put my focus on 24 in the picture menu.
i dont know if this black box do me any good cause i just use my pj on a flat screen.
anyone suggestions whether i should take it out or not?
Sparky015
Posted: Wed Feb 03, 2010 2:35 pm    Post subject:
Do those dip switches on top shut it off? You may want to PM Scott (TSE), and he can give you some good direction.
~Paul
dvh99
Posted: Wed Feb 03, 2010 2:44 pm    Post subject:
now the house to have the room for imax Smile
dvh99
Posted: Wed Feb 03, 2010 2:52 pm    Post subject:
sparky i turned off the dip switches but still my focus has to be set at 24 any ideas?
Posted: Wed Feb 03, 2010 2:55 pm    Post subject:
That is in the Geometry section, its has nothing to do with focus. The reason your focus is at 24 is the magnet's gauss is not what it should be. nothing you can do about that till Chris makes his re gaussing magnet rig, or send them to VDC to do. Or buy another set of focus coils.
dvh99
Posted: Wed Feb 03, 2010 2:58 pm    Post subject:
would these new focus coils be expensive or curt do you have some lying around?
Posted: Wed Feb 03, 2010 3:01 pm    Post subject:
Its no big deal, the amp has enough head room . Only if you notice focus drift then you might consider new coils. I know Paul Butler in england is selling a set. he has a vim and some other stuff on the UK e-bay. Look for it.
dvh99
Posted: Wed Feb 03, 2010 3:19 pm    Post subject:
tx again athan no there is no focus drift its just that i like my settings to be around 50.
more psychological then a necessity.
Posted: Wed Feb 03, 2010 4:28 pm    Post subject:
I had a FGM with that box, I took it off because the customers machine was having wierd problems, unsteady (shaking) picture, etc. not sure this was the cause but it's better to take off non-factory add-on crap if you don't need it.
Posted: Thu Feb 04, 2010 1:01 am    Post subject:
They're not new. They have to be built from existing Kanto-Denshi focus yokes, which must have at least a 9 pin connector on them if they're to be in a Marquee 8500 or 9500. The adaptation of them to being ideal for a Marquee requires
rewinding the internal coils and changing the magnetic strength so that it is optimized for the Marquee focus system.
I will not be able to remagnetize the original Thomson yokes due to size limitations on the toroid I'm using. I wasn't able to get the toroid I really wanted. Some jackass beat me to it and is probably using it for a doorstop. The K-D yoke magnets
will JUST fit. The Thomson system is too large in diameter.
It'll be at least a few more weeks before my remag rig is set up and tested. I've also got to get a gauss meter.
Fortunately, the fixtures I need are something I can make for myself.
CJ
