jradwanski
| Posted: Mon Feb 01, 2010 4:36 pm Post subject: the copper strap on marquee tubes |
I will be replacing the tubes in my 9500. I need to know where to get the copper grounding strap for the tube bell. I tried removing the old one and it is falling apart. Any ideas would help greatly thanks.
John
| Posted: Mon Feb 01, 2010 4:43 pm Post subject: |
Hello
I have few here, pm me with your address.
| Posted: Mon Feb 01, 2010 6:41 pm Post subject: |
I have seen VDC tubes with aluminum duct tape instead of the copper. And without the yellow tape either.
I think as long as you have a conductive tape that connects to the grounds you are probably ok.
zGman
| Posted: Tue Feb 02, 2010 2:59 am Post subject: |
On the tubes from VDC with the ground wires soldered to the tape -
that is actually lead tape - hard to find (can't solder to Al).
Copper would be a good alternative. Also, when removing the
original Marquee foil tape, it helps a lot to use a heat gun to
soften the adhesive. Too much heat will melt the clear tape.
