deej84
| Posted: Tue Jan 26, 2010 10:12 pm Post subject: Help with new Moome attached to Sony 1252 |
I'm having problems getting a signal through the new Moome to my Sony 1252. I had a first generation Moome that was only working over component, but wouldn't work over DVI(the picture would cut out over 20 seconds when using my Toshiba HD-DVD player and I'd get no signal using my Pioneer Blu-ray player). I decided to upgrade to the new Moome FullHD 1.2 V2 but when I plugged it in I couldn't get a picture. The DET light doesnt come on, on the front of the board. Does this mean it's the HDMI signal that's failing? I don't have a different shorter cable to compare with. On the old card it didn't matter the length of the cable. Each cable that I borrowed at the same effect. Should I order a new cable, and if so what ones do you recommend.
Dustin
