till
| Posted: Mon Jan 25, 2010 4:44 pm Post subject: Barco Data 600 Convergence Board failure |
Hi guys,
i have a barco data 600 projector, running at pal (576i) 16:9 with a dvdplayer and dvb-s receiver connected via rgbs. It worked fine for five years, but yesterday it broke while i was watching a movie.
First the convergence seems to fail and the picture turns dark within a second. I switched the pj off and found two defect fuses, F3 and F4 on the "Switched mode power supply module". Both are 250V/3.15A T. Because I want to finish the movie I looked for spare fuses and found two 250V/5A ones which i used to replace the broken ones. Yes, it turned out to be a bad idea. I was able to watch another 20 minutes or so, then the deflection fails again. I disconnected the power, waited for several minutes and hours but still the same situation:
The convergence on/off switch does still work as well as the test pattern/video input switch and the on/off switches for the individual tubes. However the convergence control potentiometers do not work anymore.
Today I replaced the fuses with the right ones, but it still does not work. I opened the convergence module and was unable to find signs of broken parts, except for some heat caused staining:
Here are two pictures, first with the convergence main switch off:
and with the switch on:
As mentioned before, turning the controls does not change anything.
I wonder if this is a known problem or if someone can help me locate the faulty component.
Big thanks in advance,
Till
| Posted: Mon Jan 25, 2010 4:47 pm Post subject: |
THe service manual is on my site:
http://www.curtpalme.com/Barco400_Downloads.shtm
At this point, with the set being 20+ years old, it could be almost anything.
I've got a convergence board that you can have, but shipping from me to you will be about $100 USD.
till
| Posted: Mon Jan 25, 2010 6:26 pm Post subject: |
thanks for the reply curt, i got the printed version of the service manual along with the projector
A nice offer, but I think it's not worth to spend $100 for fixing the old machine.
I will start to check the single components and see if i can repair it, suggestions for starting points are welcome.
Otherwise I'll have to change to HD and buy a barco 808 or so
dmarnold
Joined: 18 Jan 2010 Posts: 73 Location: St. Louis, MO
| Posted: Sat Jan 30, 2010 4:35 am Post subject: got one in the garage |
hey, i got a barco data 600 Retro 67 in my garage you could possibly get parts from.
What do you need?
_________________ enjoy today, for change is on the way
till
| Posted: Sun Jan 31, 2010 8:26 pm Post subject: |
thanks for your offer, I think I need a new convergence module and/or the switched power supply module. however the shipping seems to be much to expensive for such an old device ..
