Problem with the Image from the Panasonic PT-106
non_0815
Posted: Wed Jan 20, 2010 12:18 am    Post subject: Problem with the Image from the Panasonic PT-106
Now that I have fixed my PT-106 and I've got the tubes working another problem came up.
I mounted the projector to the ceiling and turned the Test Pattern on for adjusting.
The bottom of the image seems ok but the top looks like it is squeezed. Almost the the whole upper half of the Image is squeezed. I hope that nothing else is broken.
Thanks for any information
Robert
non_0815
Posted: Thu Jan 21, 2010 12:16 am    Post subject:
OK I figured out the Problem with the upper half of the image was the Resistor R4735 on the PC Board A. Now I can see the whole Image but I am going crazy adjusting it. The cross hatch pattern is sort of pillow-formed on the upper and lower end of the picture - bowed inwards ... I wonder if this is another Resistor or just an adjustment problem. The normal adjustments don't go this far as to that the bottom and the top line is straight.
Any suggestions?
Robert
Posted: Thu Jan 21, 2010 12:53 am    Post subject:
Any suggestions?
Robert
Hi Robert, if it looks like a pillow that's usually the pincushion adjustment.
