| Posted: Mon Jan 18, 2010 5:18 pm Post subject: Swapping parts and tubes between NEC PG + and a NEC PG Xtra |
Questions for NEC tweakers...
I have here an NEC PG Xtra and a PG+. Both projectors run well.
The Xtra has crispy fried tubes and the PG+ has fresh minty tubes. I know that you can't just swap tubes between the two (I think I know that anyway). However, would it work if I took the full tube assemblies including magnetics and hardware from the PG+ and put that into the PG Xtra? Has anyone tried this before?
Doc gave me these projectors for free instead of throwing them away, and I am setting one up for a friend of mine FREE of charge. Do you think swapping the tubes is worth it, or should I jsut give him one or the other of the projectors.
The tube wear is heavy on the Xtra, but if I stay inside the wear pattern the projector still look good. Attached are screen shots of the Xtra on a piece of wrinkled black out fabric taken with my crappy camera... so it looks MUCH better in person.
Not bad for burnt tubes eh? Maybe I should leave well enough alone!
| Posted: Mon Jan 18, 2010 5:42 pm Post subject: |
Craig, pink looks good on you!
Try it. I haven't.
My next experiment is to try Xtra system boards in a PG+. I am completely out of PG+ system boards, and need a test chassis....
| Posted: Mon Jan 18, 2010 5:48 pm Post subject: |
Craig maybe your ideas of "crispy fried" is different from mine? If the tubes were really that burnt then the hawk would be purple instead of white.
MY 2 cents, since your doing this as a freebie, why make it harder on yourself than it needs to be. Install the Xtra as-is and the guy will be thrilled. Save the PG+ for someone else.
| Posted: Mon Jan 18, 2010 7:38 pm Post subject: |
| Curt Palme wrote: | Craig, pink looks good on you!
Try it. I haven't.
My next experiment is to try Xtra system boards in a PG+. I am completely out of PG+ system boards, and need a test chassis.... |
I figured you would know for sure Curt
Maybe someone else has tried it?
| Posted: Mon Jan 18, 2010 7:39 pm Post subject: |
| draganm wrote: | Craig maybe your ideas of "crispy fried" is different from mine? If the tubes were really that burnt then the hawk would be purple instead of white.
MY 2 cents, since your doing this as a freebie, why make it harder on yourself than it needs to be. Install the Xtra as-is and the guy will be thrilled. Save the PG+ for someone else. |
Oh, the tubes are toasty... I'll take a photo of the green and post it.
I had to do some serious tweaking on the cuts and drives to balance out the colors. I have green running near the max and red very near the minimum. Honestly, I really didn't think the thing could possibly look this good!
Elaine Benes
| Posted: Mon Jan 18, 2010 8:03 pm Post subject: |
You can't run parts between the two chassis, period. They just don't interchange, they are more different than between Xtra's and XG's....
Leave the burned tubes in the Xtra and set up around them, you can EASILY make a very, very good picture with burned tubes, especially with an EM focus projector which will show absolutely no sign of the wear in terms of focus(it will still be very sharp).
The PG Plus is a VERY VERY good looking projector, and in my opinion, the absolute easiest NEC to setup WELL. It doesn't have any of the line distribution issues that virtually all later models had, the color is superb, focus and sharpness are above reproach. Don't discount the Plus just because its an older chassis, its a VERY good looking projector.
With NEC's the only thing that blocks getting a good looking picture is static image burn in, I've had ones with tubes almost burned black, and you could still get a good *looking* picture out of them.
Also, NEC's are the LEAST acceptable to swapping boards and parts between chassis of any projectors I've ever encountered. They are also the hardest to get back to "factory" type performance after they've been "messed" with. You can not swap the tubes from the Xtra to the PG Plus, even if you leave the magnetics in place, they use different tubes, the HV lead is even oriented 180 degrees from the Xtra to the Plus.
Technically, the Plus blue and red tubes will work in an Xtra, but they are not exactly the same and you can run into issues. I've used a PG Plus blue in an Xtra, but it was a hack solution which wasn't ideal, the HV lead was just barely long enough, and the connections for the upside down neckboard were also strained...
Seriously, set up the Plus and be amazed at how good they are, they're really an unsung hero among crt projectors. They perform REALLY well, and are a LOT quieter than any NEC after them too...
| Posted: Mon Jan 18, 2010 8:05 pm Post subject: |
BTW draganm, which projector would you rather own, the PG+ with good tubes, or the PG Xtra with shot tubes?
Just curious which projector my friend would be happier with. Anyone can chime in.
Elaine Benes
| Posted: Mon Jan 18, 2010 8:08 pm Post subject: |
The PG Plus with perfect tubes is a MUCH MUCH better choice...set it up and see, it will only take 20 minutes if it hasn't been screwed with...
My first "lot" of projectors was three PG Plus's, they're really nice projectors...
| Posted: Mon Jan 18, 2010 8:15 pm Post subject: |
| Elaine Benes wrote: | You can't run parts between the two chassis, period. They just don't interchange, they are more different than between Xtra's and XG's....
Seriously, set up the Plus and be amazed at how good they are, they're really an unsung hero among crt projectors. They perform REALLY well, and are a LOT quieter than any NEC after them too... |
Great info, thank you.
So I am pretty sure I will just leave both projectors as is. I mean, this is a free job so why make it harder and potentially problematic.
The color on the Xtra that I already set up is very good. It has the color corrected lenses and the gamut looks superb and very close to Rec709. Mind you, I did the set up photoed above with no instruments, so I don't know how close the gamut really is, but it's nice to my eye for a free projector (or even a pricey one).
When I get the PG+ in the house I'll do a setup on it as well and compare the two.
Does the PG+ have the ability to support a point convergence board? The Xtra does not have a point board in it now, but I thought I would try and find one for the projector... anyone have a point convergence board they would like to donate to the cause ?
Another questions... I know it is easy to overdo an NEC and wind up with it overheating. I want this projector to have the fewest potential problems so I do not want to push it at all. I noticed that on the Xtra that even with the width maxed out in the alignment controls (1080i) that the image was rather small on the tube face. Is it ok to tweak the width coils on the PG+ to make the image larger for 1080i? Or will I run the risk of the projector over heating?
Elaine Benes
| Posted: Mon Jan 18, 2010 8:28 pm Post subject: |
Start reading on the NEC's there's lots to pick up...
There is a global width pot on the main Def board to tweak the width...
As with any crt projector, the way to run it easy is to do a VERY good mechanical alignment and setup, with NEC's the placement of the projector is of vital importance. They don't have continuously variable lens flapping, so you need to have the projector in the optimal position relative to the screen to get perfect optical focus. Also, for NEC's you *shouldn't* need point convergence. It is fairly easy to get the convergence pretty much perfect without using Point. But yes, you can easily add a point board, if/when you find one...The point boards from PG's and PG Plus's are interchangeable, but not with the Xtra's, they are, like with all things Xtra, unique...
Plus's generally run a LOT cooler than Xtra's or XG's, in my experience, which is likely why they make so much less noise, fewer small fans needed to keep things from burning up...The only concern heat wise in a PG Plus are the STK's on the convergence and focus boards, but they are heat sinked to the entire bottom of the chassis, so cooling is fairly good to begin with...
Don't use the internal test patterns to set up your NEC's, they work ok, but you'll notice the results from a test pattern from your source will be more accurate and last longer...
| Posted: Mon Jan 18, 2010 10:21 pm Post subject: |
| Elaine Benes wrote: | Start reading on the NEC's there's lots to pick up...
Don't use the internal test patterns to set up your NEC's, they work ok, but you'll notice the results from a test pattern from your source will be more accurate and last longer... |
I have had numerous clients with NEC over heating issues over the years. I am not an NEC guru, but I thought that the overheating was generally due to width being run too high. I have heard of and experienced, streaking from overheating on screen, and parts frying in the projectors. The NEC's are not as durable as the Sony's and Electrohome/Marquee machines.
I really don't want to push this projector, so if anyone has advice for running the projector with STOCK cooling without overheating I would like to know. Worst case, I will just leave the width coils in their original location.
Setting up this projector is easy, I just want to make sure it lasts after I leave
benareeno
| Posted: Mon Jan 18, 2010 11:01 pm Post subject: |
set it up as per the manuals throw distance...it should run quite easily if you do. Premature tube burn is a possibility, but if the tubes are good, run the contrast low.
Also, don't forget...if you want to see even better colors from the NEC...defocus blue even more, it will make a big difference to the linearity of the greyscale.
Elaine Benes
| Posted: Tue Jan 19, 2010 12:28 am Post subject: |
Where exactly are these "width coils" you keep referring to ??
I'm pretty curious, as I can't for the life of me find them in my PG6100 out in the garage...
There is a HWidth adjustment pot on the Def board, you *can* use that to adjust the width wider than the factory set width, but you are inviting failure if you change a factory calibrated setting without knowing what effect it will have. Right ?
I'm not sure where all this "streaking" you've seen has come from either, I've owned 20 or more NEC's, PG's, PG Plus's, Xtra's, XG's every type, even a few 10PG's and I've never seen any hint of "streaking" except perhaps in one projector that had the reference mechanical white balance completely screwed.
There is a general recommendation handed out on forums about "maximizing raster usage" or some such pap, it may be great advice for a Barco*(its in their manuals in fact), or even good for a Marquee, but for an NEC, if you want to avoid trouble, and have an EXCELLENT image, follow the directions. That's all that is needed.
| Posted: Tue Jan 19, 2010 1:16 am Post subject: |
The system boards are definitely different. If you have questions on other boards I can look them up.
| Description: |
| Filesize: |
183.44 KB |
| Viewed: |
4179 Time(s) |
| Description: |
| Filesize: |
201.07 KB |
| Viewed: |
4177 Time(s) |
| Posted: Tue Jan 19, 2010 1:19 am Post subject: |
The width pot is on the deflection board. If you choose to adjust it I would recommend first turning off and unplugging the projector and rotating the pot back and forth to clean the wiper in the pot. Adjusting it when its dirty has been known to take out the output transistor.
| Posted: Tue Jan 19, 2010 7:00 am Post subject: |
There are no width coils on a NEC, that is a Barco thing.
I also have run a PG blue in an Xtra, it does work. But the G2 settings are quite different. I wouldn't do it if I could avoid it, and the plus chassis is almost as good (Paul thinks it's better).
With all PGs I would add a heatsink to the baseplate opposite the C and F drives, and some small fans to the deflection coil. Then they do not overheat.
The width pot should be set according to the procedure, 1.8v at PA Pin 2 to ground, with a video signal at 100% width.
There is a cap that needs changing on the def board from 47uf to 470uf, it is the big one front middle. NEC screwed up, the parts list says 470uf in the service manual, but they fitted 47uf. It needs a high ripple cap.
A PG Xtra/Plus is the best air coupled projector. Full stop. Not as noisy nor prone to streaking/raster visibility as an XG, as sharp as any other AC model, and colour filtered out of the box.
Oh, and basically none of the boards will swap.
benareeno
| Posted: Tue Jan 19, 2010 7:13 am Post subject: |
Thus my wanting to make a PGLC projector....but i need a workable chassis...hmmmm.
It would have the c-elements and lenses from a G70 which I can just sense wasn't meant to be...I feel a deep hatred toward that projector now. I would love a PG+LC...quiet and sharp, does 720p in a snap....adding the LC optics would be so freakin' sweet
| Posted: Tue Jan 19, 2010 3:27 pm Post subject: |
| Elaine Benes wrote: | Where exactly are these "width coils" you keep referring to ??
There is a general recommendation handed out on forums about "maximizing raster usage" or some such pap, it may be great advice for a Barco*(its in their manuals in fact), or even good for a Marquee, but for an NEC, if you want to avoid trouble, and have an EXCELLENT image, follow the directions. That's all that is needed. |
Sorry, I was talking about the width pot, not width coil. But yes, I have had many clients widen their image with the width pot and often the projector is fine. However, after doing this the NEC's seem to have overheating issues sometimes (or often).
This is where the streaking can come in, after the projector gets too hot. It's not really streaking either, it's weird video distortion that happens near the edges mostly and kind of streaks into the image.
But I think you are right, don't maximize the phosphor usage on a NEC. Just follow the instructions and use the projector as is without tweaking. I think that's how this one will be set up at my friend's place anyway
| Posted: Tue Jan 19, 2010 3:28 pm Post subject: |
| macgyver655 wrote: | | The width pot is on the deflection board. If you choose to adjust it I would recommend first turning off and unplugging the projector and rotating the pot back and forth to clean the wiper in the pot. Adjusting it when its dirty has been known to take out the output transistor. |
Good advice, thanks!
| Posted: Tue Jan 19, 2010 3:29 pm Post subject: |
| Mark_A_W wrote: | There are no width coils on a NEC, that is a Barco thing.
Oh, and basically none of the boards will swap. |
More good info, thanks Mark.
