Problem with Panasonic PT-106/ 106
non_0815
Posted: Sun Jan 17, 2010 9:02 pm    Post subject: Problem with Panasonic PT-106/ 106
I habe a Panasonic PT-106.
The problem is that the Tubes don't start. So I don't see anything. I guess that there is some problem with the power.
When I switch it on everything looks fine - except that there is no picture (test pattern)
The Fan is going the red LED on the D and E-Board is on and the end of the Tubes are glowing.
I know that this model is similar to the PT-105 so I already downloaded the Techguide and Servicemanual from curtpalmes great page.
I checked the parts from the service manual on page 19 but this seems ok.
How it happend:
The crt was on and working fine. I left the room for a moment and when i came back the tubes were off...
I'm not so familar with crt Projectors so I hope sombody can help me to fix this great pice of technic.
Many thanks in advance
non_0815
Posted: Mon Jan 18, 2010 9:21 pm    Post subject:
Today I lookt over it again and found something, but I don't know what causes the problem. On the P2 Board on P34 should be on pin 6 -28V but I have only 0.3V. Hopefully someone can help.
To see what I mean please look at
http://www.curtpalme.com/docs/PanasonicPT105_Service_Supplement1.pdf
on page 23 and 24 is the P3 Board shown.
I really dont want to bury the Projector.
Robert
non_0815
Posted: Tue Jan 19, 2010 6:40 pm    Post subject:
finally i solved the problem.
it was the resistor R9312 on the P3 PC Board.
if someone got the problem that he have no image at all check the -28V on PC board C connector C1 Pin 6...
Many thanks to Curt Palme for the detailed Manual from the Panasonic PT-105
Posted: Tue Jan 19, 2010 7:04 pm    Post subject:
Good servicing, that's one I've never had to repair. I've had two through here, and they both worked fine.
