Das444
| Posted: Sat Jan 16, 2010 1:49 am Post subject: HD Fury 2 with Sony 1252 |
Hi all,
I would like to know if anyone is running the Fury 2 in to a IFB 11 input card with any sucess. If so could you tell me what the jumpers are set at. I'm having no luck with mine I just get a rolling picture then it goes blank. My system works fine with other cards I was trying to upgrade to HDMI input.
Thanks Dan
| Posted: Sat Jan 16, 2010 4:14 am Post subject: |
Hi Dan,
first question. Do you have the power supply?
Second, what's your source?
Third, What resolution are you sending the 1252?
Fourth if it's a PS3 or DVD player do you have 24 fps/24Hz turned off?
Das444
| Posted: Sat Jan 16, 2010 1:40 pm Post subject: |
| AnalogRocks wrote: | Hi Dan,
Yes
I have sony blue ray player BP-360, Play Station 3 slim,Dish Network HD box VIP-211
all going into a Pioneer Elite VSX94TXH.
all HDMI Input to reciver.output to sony 1252 HDMI.
I have tried all 480i,480p,720p,1080i 1252 will not do 1080p. 720p looks too soft.
Fourth if it's a PS3 or DVD player do you have 24 fps/24Hz turned off? YES |
Das444
| Posted: Sat Jan 16, 2010 4:00 pm Post subject: |
I think I found the problem. I got this from Mike Parker and it is wired right to the Fury board the V and H sync wires came loose. Thanks for all your help.
Dan
| Posted: Sat Jan 16, 2010 4:57 pm Post subject: |
| Das444 wrote: | I think I found the problem. I got this from Mike Parker and it is wired right to the Fury board the V and H sync wires came loose. Thanks for all your help.
Dan |
Ahh is that the MP moded HDFury2? Cool!
