scottatl
| Posted: Sun Jan 10, 2010 3:06 pm Post subject: So who will be first with HDMI 1.4 for us?? 3D capabilities |
I know a lot of folks think the 3D is a gimmick, but it should be fun. I have read some threads on if HDMI 1.3 will be able to do it, but is seems it is one of the key changes for 1.4. Years off until mainstream, but I hope a few of our inventor friends are already thinking of it.
What do you all think of 3D on CRT?
3D Over HDMI
The 1.4 version of the specification will define common 3D formats and resolutions for HDMI-enabled devices. The specification will standardize the input/output portion of the home 3D system and will specify up to dual-stream 1080p resolution.
| Posted: Sun Jan 10, 2010 7:43 pm Post subject: |
The highest end CRT projectors undoubtedly have the bandwidth required. If we just get Moome (or whomever) to come up with a new 3D VIM card, and the frame rate is within limits, we'll have 3D soon.
I'm guessing that the default for 3D at 1080p will be 24 FPS per field. Total bandwidth will be 1080p/48, which is no challenge, as most
Blu-Ray players default to 60 FPS in 1080p mode. (Or at least Sonys do.)
I'm not the guy who's going to be engineering the 3D players or glasses for home use, but if I were to do so, here's how I'd do it:
The player comes with an IR emitter (either on the front of the player or a small remote one connected via a cable) which is used to
send a sync signal to the glasses, which are wireless, battery operated, operate on the LCD shutter principle, and have an IR receiver
in them for receiving the sync pulses.
The player also includes a delay adjustment menu which adjusts the timing of the emitter sync pulse. It also includes a test pattern
which you use with the delay adjustment until the image has the correct 3D effect and it's clean. This is necessary because every
TV has a processing delay, and it's not the same from one set to another. So it will be necessary to trim the timing of the glasses
in some way. Once the setup is complete, the glasses only get the occasional sync pulse to alleviate any possible drifting problems.
That's how I'd do it. I can't speak for how it WILL be done, though, but frankly I'd expect someone to do it just like this.
Too bad I can't implement it myself, because it's certainly a patentable principle. But if you can't make it, you can't patent it. I don't
have the skills or resources to bring it to reality.
CJ
| Posted: Sun Jan 10, 2010 8:06 pm Post subject: |
I heard they need 120hz refresh rates Chris. if its a single PJ system then only a blend set up will be able to do it, on my Tv-ones i run 1064x800@72 to each PJ, i have tried that res at 96 and 120 and both are capable but the 120 is harder to get fully resolved, maybe with MP vim it might be doable or after I do some work on it, but it definitely a nice pic and super duper smooth pans. Right now both PJ's are stock except for the CMM which I had to modify.
| Posted: Sun Jan 10, 2010 9:58 pm Post subject: |
At 1080p x 120 Hz, you'd need a horizontal scan rate of 130 KHz, roughly, and a total video bandwidth of about 375 MHz.
I think that we may have to settle for 1080i x 120 Hz instead. This would still push the bandwidth requirement but would fit in the scan
rate capabilities, anyway.
So who's good at redesigning the VIM and neck cards for 400 MHz bandwidth?
I've been trying to find the actual specification technical data for 3D Blu-Ray. So far I haven't actually found it but I have found a
reference that says it only supports 24 FPS per channel. If that's true, we won't have any problems.
CJ
mhalsan
Joined: 09 Nov 2007 Posts: 146 Location: Astoria, Oregon
| Posted: Sun Jan 10, 2010 10:25 pm Post subject: |
That would work. There might be an issue with flicker due to 24 fps per eye, but that'd be a subjective decision.
There is an article on the web about a Mitsubishi 3D adapter, presumably for their own sets, but if it uses the method described above, perhaps we can adapt it for our equipment.
http://www.twice.com/article/442871-Mitsubishi_Unveils_3D_Blu_ray_Adapter_For_Legacy_3D_Ready_Sets.php
Thanks, Mark
_________________ Sigh. We are getting aggravated (yes, we are....)
Mr. Green
| Posted: Sun Jan 10, 2010 11:39 pm Post subject: |
As I posted on the other 3D thread. Here's a link for you...
http://www.letsgodigital.org/en/24286/blu-ray-3d/
Boilermaker
| Posted: Mon Jan 11, 2010 12:51 am Post subject: |
Because of the extremely high bandwidth requirement, I just can't see this working with any crt setup except a blend.
I don't think that using an interlaced signal to reduce the bandwidth will work as the second 1/2 of each field would interfere with each other. I think that a progressive signal is necessary.
CJ - I agree with your "proposed" design. I wonder if there is enough light output from any display device in the infra-red range for them to super-impose the synch signal with the video? It sure would make it easy.
I'm hoping that all I will need to make it work with my blend is a Moome box that will give the 3D BD player a proper EDID to send the 48hz 3D signal. I.m excited about the possibilities.
Athanasios - I haven't had the time to try 120hz refresh like you have. What do you think of the results?
Bob
| Posted: Fri Jan 15, 2010 2:06 pm Post subject: |
In the theater, 24 FPS has been the standard forever. Does flicker really bother anyone in the theater? I think that dual 24 Hz channels would be quite tolerable.
I will say that when I saw Avatar in 3D, I did see obvious evidence that each channel was operating at half the framerate of the full signal.
In fast motion sequences this was pretty easy to spot but I didn't find it annoying.
If 1080p60x2 is too much to handle, 720px60x2 should fit within our bandwidth limitations with no problem, for the better projectors,
anyway, and there's nothing wrong with a good 720p picture.
1080i with the interlaced fields each being the separated channels, at anything over a total framerate of 60 Hz, should also be acceptable.
My belief is that the 3D-capable players will allow selectable output resolutions and framerates, just as any 1080p capable Blu-Ray
player allows you select 1080i, 720pi, and 480p and 480i if you wish to. It makes sense to be able to deliver a reduced quality 3D
image to the customer, and get him wondering how much better it would be if he went out and got a new set that could take the
maximum quality version of the signal. Good sales tool. And remember, it's ALL about sales.
CJ
Boilermaker
| Posted: Fri Jan 15, 2010 7:11 pm Post subject: |
| Quote: | | I think that dual 24 Hz channels would be quite tolerable. |
CJ, I think the problem would be only with crt projectors, not digital. When a digital projector runs at 24hz, all pixels are lit up for the entire 1/24th of a second - with a crt, the pixels are scanned from top to bottom, one row at a time. In this case, each pixel is atually energized for less than 1/2,000,000th of a second, neglecting retrace times. While each pixel doesn't decay instantly, it is pretty quick and therefore I don;t think would work.
I used to watch DVD's at 960P with a 48hz refresh and didn't really mind the flicker too much, but since I am now running 72hz. I find it preferrable.
| Quote: | | 1080i with the interlaced fields each being the separated channels, at anything over a total framerate of 60 Hz, should also be acceptable. |
I'm not sure about this one, so follow my reasoning on this. If we display an interlaced signal, we are only showing 1/2 of each picture during each period (either odd or even lines) and then the other 1/2 for the next period. Unless we double the refresh rate, we would only see the first half with one eye, and then the other 1/2 with the other eye. Sorry about being so confusing, as I just read this sentence and it is confusing, but hopefully you can figure out what I am trying to say! I think it will only work with progressive scanning.
The reason I'm excited about the possibility of 3D is that with a blend, you can handle the high frequencies. I realize there are some other thinks to overcome (light output, synching the glasses, etc.), but I haven't seen a deal killer yet!
Bob
| Posted: Fri Jan 15, 2010 11:19 pm Post subject: |
The prospect of hotrodding the complete Marquee video chain up to a system bandwidth of 375 MHz is daunting if not actually terrifying. But that's what the Extron bandwidth calculator says would be required for dual channel 1080p at 60 Hz per channel.
I'm just hoping that when 3D blu-ray machines come out, they can run 3D at LESS than top resolution and framerate. I'd be inclined to
believe that they can do so.
For the vast majority even of CRT enthusiasts, the option to blend two projectors is no option at all. It's not going to happen.
I think that I might be able to pull off a side by side stack in terms of the physical requirements, but I can't afford another 9500LC with perfect tubes, MP Gen 2 mods, Advanced Frankenyokes, HD10Fs, and all the other goodies that go along with it.
Blends are an unrealistic option for most of us. Frankly, the best way I could do a blend is to get a second DLP lens and run the pair of
Barco SLM R6 3 chip DLP units together, that I have in my garage at this moment. Turn the entire garage into the home theater.
But even though I have the projectors, it's still unrealistic.
CJ
| Posted: Sat Jan 16, 2010 12:48 am Post subject: |
I talked to Jim Peterson of Lumagen and also Mike Parker a few days ago specifically about 3D on CRT. It looks like BD 3D will be 1080p 48Hz. Digital 3D sets will then internally multiply the input frequency to either 120Hz or 240Hz.
What Mike Parker suggests is that we shoot for 1080i 120Hz for 3D on CRT. This should provide a similar look to 1080p 60Hz (same bandwidth), but also be an even multiple for 3D applications. Jim says the next Lumagen Radiance processor will be HDMI 1.4 compliant for 3D. Lumagen also told me they are planning to support 1080i 120Hz for 3D on CRT So theoretically, if your projector can run 1080p 60Hz, it should be able to also run 1080i 120Hz.
Also, it looks like we may be able to do this with our existing input devices from Moome and HDFury.
One thing that concerns Jim though is the slower than digital decay rate on CRT's. He thinks this could be an obstacle because 3D needs very fast response on/off.
We'll see...
| Posted: Sat Jan 16, 2010 1:32 am Post subject: |
Incidentally, I read about how 3D is to be implemented, using shutter glasses and an IR transmitter. Just as I predicted.
CJ
mhalsan
| Posted: Sat Jan 16, 2010 1:33 am Post subject: |
I'm going to have nvidia's 3D kit by next weekend. Their literature claims compatibility with CRT at 100Hz or higher. I'll let you know how it goes.................We'll see.
I'm betting the phosphor lag is the biggest holdup. I've already tried running at 100 and 120Hz at higher resolutions, there is some resolution loss, but nothing I'd consider to be a deal-killer.
Thanks, Mark
| Posted: Sat Jan 16, 2010 3:46 pm Post subject: |
| mhalsan wrote: | I'm going to have nvidia's 3D kit by next weekend. Their literature claims compatibility with CRT at 100Hz or higher. I'll let you know how it goes.................We'll see.
Thanks, Mark |
Wow, that is very exciting to hear. I can't wait to find out about your results.
What projector do you have again?
If I recall, the P19LUG's have the fastest decay rate so these may wind up being the best tubes for 3D applications. Thankfully, the entire industry seems to be moving towards P19LUG's for all 9" projectors.
| Posted: Sat Jan 16, 2010 3:52 pm Post subject: |
| cmjohnson wrote: | Incidentally, I read about how 3D is to be implemented, using shutter glasses and an IR transmitter. Just as I predicted.
CJ |
This also sounds like really good news for us because it means we don't need anything special in the display its self.
It seems the minimum one needs for 3D on CRT is a Blu-Ray player that supports 3D, and a video processor that can output 120Hz at a resolution, preferably 1080i. Or a HTPC with BD and 3D support with a high refresh rate.
I don't see why we would even need to change out existing input boards as long as they support the input frequency we need... and for example Moome's new ones should support 1080i 120Hz.
| Posted: Sat Jan 16, 2010 7:57 pm Post subject: |
What I've read is that the plan is for 3D to be output at 1080p24 x 2. This is well within the capabilities of practically all better CRT projectors. However, some players may have higher refresh rates available, just as some players were built to output 1080p before 1080p was formally adopted as a standard.
CJ
| Posted: Sat Jan 16, 2010 9:45 pm Post subject: |
| cmjohnson wrote: | What I've read is that the plan is for 3D to be output at 1080p24 x 2. This is well within the capabilities of practically all better CRT projectors. However, some players may have higher refresh rates available, just as some players were built to output 1080p before 1080p was formally adopted as a standard.
CJ |
Yeah, you are right. But what I meant is that a high refresh rate is required and that digital displays will multiply the 48Hz internally to either 120Hz or 240Hz. I have not heard of any sources (BD) that will supply the required 120Hz or 240Hz. The display is responsible for multiplying the input frequency, hence the display must be "3D ready."
CRT can do the high refresh rates, but we will still need sources to perform the frequency multiplication up to 120Hz (or whatever) before it hits the CRT projector. Lumagen is planning to provide a processor that will do the multiplication up to 120Hz for 1080i on HDMI. Incidentally, the RadiancePRO will also be able to do 1080p @ 72Hz for 2D.
And it sounds like the 3D HTPC's are coming now that can do the frequency multiplication for us.
I wasn't too excited about 3D... but as we get closer I am getting excited.
| Posted: Sat Jan 16, 2010 11:15 pm Post subject: |
I disagree that we "need" 60 FPS per image on a CRT projector. I think that 24 might be a bit flickery, but if we got 48 per image, I think that this would be quite satisfactory. However, that would equate to 1080px96, which is still a pretty stiff bandwidth requirement.
I need to drag a PC home, one with a good video card, and start playing around with it. Actually see for myself what 1080px48 would look
like, or even slower if the machine will sync up.
CJ
| Posted: Sun Jan 17, 2010 12:46 am Post subject: |
| cmjohnson wrote: | In the theater, 24 FPS has been the standard forever. Does flicker really bother anyone in the theater? I think that dual 24 Hz channels would be quite tolerable.
CJ |
Ahh....you do realise that they double the 24fps to 48hz in the cinema?
Even then, I find the 48hz flicker UNBEARABLE.
Avatar, at 120fps (per eye I think), was rock solid. Even apart from the 3D the image was the best I've seen. Sharp, and NO FLICKER. I vastly prefer a digital projector in the cinemas.
Back to the main discussion..
If 1080i 120hz will work for 3D, then maybe 1080i 96hz will work too (?)
| Posted: Sun Jan 17, 2010 1:48 am Post subject: |
| cmjohnson wrote: | I disagree that we "need" 60 FPS per image on a CRT projector. I think that 24 might be a bit flickery, but if we got 48 per image, I think that this would be quite satisfactory. However, that would equate to 1080px96, which is still a pretty stiff bandwidth requirement.
CJ |
I don't think any of the tubes can resolve 1080p 96Hz even if there were a projector with a signal path that could pass it without crazy attenuation. But I do think actually looking at 1080p 48Hz is definitely worth testing. I mean you never know, it might look decent or interesting.
