Can somebody please clear some things up for me?
JorisS
Posted: Thu Jan 07, 2010 7:42 pm    Post subject: Can somebody please clear some things up for me?
Hi all,
after swapping out all fans on my NEC XG110LC and installing the newly purchased Moome HDMI card, I'm in the process of setting up the projector now. It's going to be ceiling mounted and before I go off drilling 4 big holes in the concrete ceiling, I'd like to make sure it's in the right place.
So what I did last time was to optimize the phosphor first, without the lenses, then put the lenses on and move the projector to the right distance so the picture fills the screen. Then ceiling mount it there.
That's correct, right? Using the calculations in the manual doesn't really cut it as the phosphor usage will be too conservative? (i.e. too small image on the phosphor?)
Now what I never really got my hands around - if I feed a signal through HDMI from my Curanta media box, 1080p in this case, the image projected from the Curanta doesn't cover the same surface as when I enable the TEST pattern. It seems to be shifted and 'doubled' up on one side, i.e. like when shifting the image too far it sort of rolls over and doubles back, as if a paper sheet pushing into a solid barrier.
Which image should I use? Should I do the setup with the built in TEST patterns, or should I somehow get the Curanta to project a test image instead? It can do JPG's, for example. I do need to have the PJ locked into a signal right? Does it actually matter if the signal is 720p or 1080i or 1080p? Can't really remember if the phosphor usage is signal related or not? It didn't seem like it was in the old apartment, but that perhaps is due to the fact I installed another input card (the moome HDMI) rather than which source I use (used to be an HTPC)?
Also, optimization of the phosphor, is that source/input related? If I instead feed 720p, would that change the size and thereby phosphor usage? Would appear rather unlogical in a way, as people don't move about their PJ with differenct input sources as far as I know Wink
I think I already knew a lot of this previously, but too much time has passed in between and I can't really seem to find my old topics and notes Sad
How should I go to work here? I'm interested in the correct steps prior to the actual convergence and alignment, making sure I'm starting off in the right spot (CTL + NORMAL should cut it, right?) and do everything right from the start.
Thanks in advance!
//Joris
Posted: Thu Jan 07, 2010 7:48 pm    Post subject:
Always set up your PJ using the source as the internal test patters will have different timings. I think some PJ's will alter their timings to match an incoming source. But its usual practice to use the external source convergence grid.
I personally use a full field 20 IRE pattern to center the image on the tube face. once that is done do as you described in your post, set it up on the floor to fill the screen and then move that location to your ceiling.
Posted: Thu Jan 07, 2010 7:51 pm    Post subject:
But, in this case, he can't use the 1080p source, because the XG doesn't like 1080p timings.
For the purposes of positioning the projector, it isn't necessary to use an external source... Just make sure the test pattern you use covers the same area the external signal would, and that you leave enough room for keystone on all corners of all three rasters, and that you'll still have good corner focus... i.e. don't get too close to the edges.
JorisS
Posted: Thu Jan 07, 2010 8:36 pm    Post subject:
Thanks for the replies. Does anybody know if the NEC alters it's timings or not? One thing I do know is that the pj switches to the test screen promptly, it doesn't click and lock onto a new signal as when switching input channel or source.
Using the media box, do you guys have any good suggestions for test patterns? It doesn't have any in-built, so I'd be dependent on jpg's or something of the likes.
I should then obviously also do the convergence and all with a source generated test pattern, right?
Lastly, in question to the input signal - if I position the pj correctly for optimal usage of the phosphor at 1080i (if I chose to go with that instead of p), will that also mean phosphor usage will be good/optimal if I should change the input signal to 720p at a later stage? Just want to make sure the mechanical setup/ceiling positioning is correct.
Elaine Benes
Posted: Thu Jan 07, 2010 9:20 pm    Post subject:
Without question, on an NEC especially, use the actual source for your setup. The NEC test patterns are generated from the sources timings, but there is still a definite discrepancy between the internal and external test patterns.
Also, before you go whole hog with "maximizing" the tubeface usage, take the time to actually complete a setup at your desired resolution, check how well you can get it setup on the edges and in the corners, then do the same setup using a tubeface size closer to what NEC recommends. I am one of the very few people who *generally* stick much closer to NEC's recommended positioning because I've seen in practical applications, a more conservative raster size leads to a raster that can be set up more precisely and focused more exactly over its entire area. NEC XG's also typically have a line distribution problem which is MUCH harder to correct the larger your raster. Getting it exactly square and straight on all edges will be quite difficult with a raster that is maximized...
JorisS
Posted: Thu Jan 07, 2010 9:23 pm    Post subject:
Cheers, that's a very interesting perspective. This will not be the first time I'll do a full setup on the NEC, although it will be the first time in the new house - also I've never been that good at it Embarassed But did previously find it hard to get proper focus towards edges, which might be explained by the above.
Thanks!
Any suggestions for good test images/patterns in proper resolutions? I've used the Nokia monitor tool before, but that was on the HTPC - the media player can't use it.
Posted: Thu Jan 07, 2010 9:25 pm    Post subject:
No CRT projectors (or PC monitors) alter the timings. They are completely driven by the signal - hence all the complicated sync stuff in the signal.
Or did you mean readjust the internal patterns? On a NEC you have to adjust phase to do this. It's not the same as Marquee phase.
But back to the original topic. Joris, you need a VP or a PC with custom timings to get the best out of your XG (or any CRT). For best results you cannot run a media player, or a bluray player directly, the image will wrap and you are stuck at 60hz. (Or 50hz, which will give a very odd cadence.)
And no, the image width will be different for different scanrates. Usually, the projector can compensate, but if you push it to a high scanrate, it may need to move back compared to a low one.
You really need to decide on a res upfront. I suggest 1080i 96hz, which means a custom res, which means a VP or PC....throw the media box away..
Yes, CTRL + NORMAL then CANCEL then ENTER will reset to midpoint.
JorisS
Posted: Fri Jan 08, 2010 1:17 pm    Post subject:
Excuse my ignorance, but what's a VP?
I might go with the laptop then, as I don't have the funds nor desire to build/buy a new HTPC really.. and the new laptop has HDMI out. Can give it a go at least and will try the suggested resolution and scan rate, cheers. In that case I can also resort to the Nokia tool again Smile
kschmit2
Posted: Fri Jan 08, 2010 2:14 pm    Post subject:
VP = video processor
Posted: Fri Jan 08, 2010 4:29 pm    Post subject:
What video card does your laptop have in it?
JorisS
Posted: Sat Jan 09, 2010 10:40 pm    Post subject:
It's a HD3470 I think... VAIO FW11E. But the mrs kind of confiscated the laptop the minute it was delivered, so guess that option is a goner Wink
So perhaps will try to build a simple budget HTPC with a HD decoding graphics card in it.
Posted: Sat Jan 09, 2010 10:45 pm    Post subject:
Powerstrip should support that chip set. I have a 3450 card in my HTPC and powerstrip works nicely. Now if you can just get YOUR lap top off the missus.
Shoujiki
Posted: Sun Jan 10, 2010 12:23 am    Post subject:
I'm not well tuned in CRT setup and that, but from my reading, the 1272 manual says to "set the projector up with the internal test patterns with the projector in "internal oscillation mode", ie. no signal input, and then once complete, redo the setup with your "first piece of equipment" connected.
Is this correct?
Regards, Kurt.
Melbourne, Australia.
Sony VPH-1272QM
Posted: Sun Jan 10, 2010 1:16 am    Post subject:
Is this correct?
No, use the actual signal you are going to be watching. Why set it up twice?
So if you plan on 1080i set it up using 1080i.
Shoujiki
Posted: Sun Jan 10, 2010 1:30 am    Post subject:
Is this correct?
It's what i thought too. Seems silly. It's what the 1272 manual suggests however.
Regards, Kurt.
Sony VPH-1272QM
Posted: Sun Jan 10, 2010 2:34 am    Post subject:
After the G90 debacle, I no longer believe that Sony is all-knowing. Smile
Posted: Sun Jan 10, 2010 2:35 am    Post subject:
Ahhh whatdaenieersknow? Laughing
Seriously though. Once you get the hang of setting that up you'll be able to do it in a flash. The Sony 12xx series projectors are a breeze to set up.
My 1252 took me 8 hours the first time with the manual. Now 45mins to an hour to get a decent picture.
Elaine Benes
Posted: Sun Jan 10, 2010 3:16 am    Post subject:
JorisS wrote:
It's a HD3470 I think... VAIO FW11E. But the mrs kind of confiscated the laptop the minute it was delivered, so guess that option is a goner ;)
You can buy a ready built HTPC with everything you need except a BD rom for $414. it is a decect bargain, and a very small computer to boot. See this thread:http://www.avsforum.com/avs-vb/showthread.php?t=1170527
There's also the prebuilt Ion boxes, very small with onboard 9300 Nvidia graphics, you can pick them up with DVD/RW for about $400., or with BD drive for about $600., less on sale...
http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=024006&cid=DPC.405
I've built a couple small ones with HD decoding graphics capability, if you want to do it REALLY cheap, you have to go to a larger form factor to get the cheap cheap motherboards. M-atx size gives you an AMD motherboard with onboard ATI graphics capable of hardware acceleration in the $80. or cheaper range, they've been as cheap as $60. on sale around here...
JorisS
Posted: Mon Jan 11, 2010 10:30 am    Post subject:
Problem with these HTPC's are the peripherals... i.e. one needs a keyboard/mouse or some fancy combination such as the Dinovo edge in order to operate. That's what I like about the mediaboxes; then again I realize while writing that one can get those IR remotes for HTPC use as well, if running Media Center.... hrm. Will give it all some consideration.
