Swapping the B-Board on a G70, not that simple?
locoman
Posted: Thu Jan 07, 2010 1:14 pm    Post subject: Swapping the B-Board on a G70, not that simple?
Hi All,
I've replaced my faulty b-board with one I got from Brian and when I power the PJ on, the tubes come barely on. I can only see the menu, with no lenses attached, when I crank the contrast all the way to 100%. I guess one has to calibrate the b-board, I found an adjustment procedure on the service manual, section 3-2-2. My question is, will that solve my problem or are there more adjustments needed to fix my problem?
Hein.
cinema mad
Posted: Thu Jan 07, 2010 3:55 pm    Post subject:
Yep, I know when Replacing the E board complete that you need to Calibrate it and the PA boards but you also need a Special Expansion link so as to allow accessibility to the board's to perform the appropriate Adjustments...
Cheers...
Brian Hampton
Posted: Thu Jan 07, 2010 11:00 pm    Post subject:
Yeah,... Section 3-3-2 is what I find as well.
Don't know why one board should be so far out of whack to another but at least that section seems to have a method for adjusting it.
It says you need the extension board but maybe there's a work-around. Like making iterative adjustments.
-Brian
locoman
Posted: Mon Jan 11, 2010 11:45 am    Post subject:
Upon closer inspection, found both boards are completely different and even the part numbers are different! So I decided to repair my old b-board instead. Got it repaired on Saturday and after a complete setup, my PJ is now running smoothly.
Brian Hampton
Posted: Mon Jan 11, 2010 12:41 pm    Post subject:
Great!...
Glad to hear it's working now.
Just came here to get an update and this one is about as good as it gets.
-Brian
