barco 701 v d50 lenses
nurse mark
TV/Projector: Barco Data 701
Posted: Wed Jan 06, 2010 10:01 pm    Post subject: barco 701 v d50 lenses
Hi, I have 2 data 701s and a sony D50. The D50 is my main pj and the 701s are gpnna be sold off when I get round to fitting a set of 8->9 rated tubes on one of them.
Question is... are the lenses between the 701 and D50 compatible and if so, which would be better ? I'm guessing both use hybrid glass / plastic lenses but if there's an easy upgrade here then I may as well make a swap if poss.
Thanks.
Posted: Thu Jan 07, 2010 1:58 am    Post subject:
What lenses does your D50 have one it? HD-6's?
nurse mark
Posted: Thu Jan 07, 2010 6:42 am    Post subject:
yup, hd6s
Posted: Thu Jan 07, 2010 7:05 am    Post subject:
nurse mark wrote:
yup, hd6s
Someone else will jump in here because I can't fully remember but I believe PT-65's are better than HD-6's. PT-65's came on SOny 12xx series projectors but not all of them.
Ile
Posted: Thu Jan 07, 2010 10:18 am    Post subject:
701s datas should have HD145, focus would be better than in hd6.
Those are straight swap, but throw is different.
There is color filtered versions (red/green tint) and non color filtered of HD145. Can't remember wich ones 701s have.
http://www.curtpalme.com/forum/viewtopic.php?p=26493#26493
If D50 tubes have tinted R/G glycols, those need to be replaced to clear ones with color filtered HD145.
PT-65's are straight swap for HD8, but not for HD6/HD144/HD145.
Posted: Thu Jan 07, 2010 2:39 pm    Post subject:
Thanks Ile,
He could get clear HD144's or HD145's
nurse mark
Posted: Thu Jan 07, 2010 10:25 pm    Post subject:
Thanks guys - I have 2 x data 701 projectors and the lenses are clear ( as the tubes are tinted ). Will give a swap onto the D50 a go and see what happens Smile
