Help with signal xg135-Moomefullhd
LanceL
Posted: Mon Dec 28, 2009 5:47 pm    Post subject: Help with signal xg135-Moomefullhd
This is a quirky one...I have a xg135 with a moome fullhd hdmi card...I am having a scenario where the pj would not sync on any signal ,shut itself off and 5 seconds later turn itself back on...then not sync on the signal turn itself on, etc and would continue this cycle.
after playing with all the sources/res/timings to no avail I pulled out the moome card...the on-off cycling stopped happening but I still can not sync on any source signal via input A /rcbhv or even after I put in my older second (InputB) rgbhv back into the pj....
I can see the pj switching between the input a and B and I can get to the menus, but I can not sync on any souce via any input on the list/menus, etc/
Anybody have some ideas...was it the moome card going bad and possibly damaging the pj with it or...? what boards/parts on the PJ need to be evaluated/replaced?
Thanks greatly for any help
Lance
moome
Posted: Tue Dec 29, 2009 11:10 am    Post subject:
can you pull all the cards out, and only use the RGBHV input or S-VIDEO input to check?
LanceL
Posted: Tue Dec 29, 2009 8:11 pm    Post subject:
Well, after some trial and error it is indeed the Moome full-hd card.....all other inputs are working normally.
If I even slide the fullhd card back into slot B with no source or hdmi cable attached the projector starts to shut on and off every few seconds....I can replace the fullhd card with a rgb card back into the same slot B on the pj and all is well
So.....were do I send the card back to you and what is the best method/route to do so
Thanks for your assistance
Lance
moome
Posted: Wed Dec 30, 2009 6:28 am    Post subject:
Dear Lance:
please email to our service email:
moome.liu@gmail.com
