What type soldering iron to buy?
wallace123456
Posted: Fri Dec 25, 2009 4:14 pm    Post subject: What type soldering iron to buy?
Well, my old low wattage iron crapped out on me. It never was really very good for board type work anyways. I have an old American Beauty 110watt iron that I used back in the old days of telecommunications. But that don't work too well on board stuff.
Looking for some recommendations for soldering iron stations. I am looking at the weller wesd51.
Any other thoughts?
wallace
Posted: Fri Dec 25, 2009 4:55 pm    Post subject:
Well I do all my very intrinsic and micro soldering with Radio Shack specials, LOL. 1 low watt (dont remember the wattage) and a 40 watt for heavier stuff and same for my desoldering device. All replacement tips can then be also purchased from Radio Shack.
A 500 dollar soldering station would not make you a better solderer...... Laughing
But if you like them then I guess whatever one seems to suit you best. Availability and price of replacement tips would be very important.
Posted: Fri Dec 25, 2009 5:13 pm    Post subject:
Wallace, i have the Aoyue 968 and bought the soldering tweezers with it. for 159 + the tweezers it has been a perfect station for my hobby, it has a vacuum charcoal filter too,
and the hot air gun is awesome for removing the Small chips and reheating the board a bit.
Id buy on extra iron too incaes you break it like i did Sad steped on it !!!
http://www.sra-solder.com/aoyue_968.htm
http://store.sra-solder.com/product.php/6373/0
beun
Posted: Fri Dec 25, 2009 5:21 pm    Post subject:
I have that Weller, it is pretty decent. If you want something realllly good go for Metcal.
ESL-0.5 Full Range Electrostatic Loudspeakers | RTC2200 Component to VGA Converter with Gamma Boost
Posted: Fri Dec 25, 2009 5:23 pm    Post subject:
My main bench iron for years has been a Weller WTCPS station. I have two of them, one on each (functional) bench, but the shop is set up for 5 benches. Problem is, CRT parts and tubes are on most of them. Very Happy
I will add a Metcal station and desolderer, I've been hooked since I've been at Marc's (Tinman's) place.
tse
Posted: Fri Dec 25, 2009 5:24 pm    Post subject:
For a little more than the cost of a soldering iron you can get a hot air rework station with soldering iron and hot air rework wand. The hot air works great for desoldering.
http://www.amazon.com/Aoyue-Dual-Function-Rework-Station/dp/B000KMNC58/ref=sr_1_8?ie=UTF8&m=AKJ57Q9VZBBO8&s=hi&qid=1261761416&sr=1-8
http://cgi.ebay.com/SMD-Rework-Soldering-Station-HOT-AIR-IRON-10free-tips_W0QQitemZ220530527052QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3358a4cb4c
These probably won't last a lifetime like a top quality soldering iron. I've had mine for a couple of years now and for hobby volume work it is fine.
Scott
Thomas Jefferson
Elaine Benes
Posted: Fri Dec 25, 2009 5:25 pm    Post subject:
Nashou66: If the quality of those tools are as good as they look, I think those prices are REALLY good, what a great find...
Posted: Fri Dec 25, 2009 6:16 pm    Post subject:
Scott and paul, i love my Aoyue!! the irons are not a strong as Id like but for the money they work great!!!! And the hot air station is awesome for removing SMD chips and using it to heat shrink tubing. And the vacum is great to suck up fumes.
Just got done using it to fixe the CCM boards on the long bows, I figured it out scott Wink Try it on the ones at VDC.
nashou
Posted: Fri Dec 25, 2009 8:35 pm    Post subject:
My favorite.... Very Happy
http://www.radioshack.com/product/index.jsp?productId=2062728
Posted: Fri Dec 25, 2009 9:14 pm    Post subject:
I also have this !!
http://www.radioshack.com/product/index.jsp?productId=2062731&clickid=prod_cs
wallace123456
Posted: Fri Dec 25, 2009 11:39 pm    Post subject:
I also have this !!
By the amount of good reviews this got, I have to try it at least for desoldering.
Looks to be a good buy.
wallace
wallace123456
Posted: Sun Dec 27, 2009 1:19 am    Post subject:
It just doesn't seem like 15 watts is enough to desolder or solder. Does it take you very long to get the materials where solder will flow?
You must have steady hands. Mr. Green
wallace
Axatax
Posted: Sun Dec 27, 2009 1:28 am    Post subject:
I have an older Weller station with soldering iron/hot air/vacuum. IMHO, I'd rather have the desoldering suction and a Rat Shack iron than a fancy single-function iron. Desoldering is were most of the destruction occurs.
Posted: Sun Dec 27, 2009 1:39 am    Post subject:
wallace
Alright, I have to edit my post. I wasn't sure what wattage my main iron was so I just checked and its a 30 watt. So thats what I mainly use. When I posted that 15 watt one above I was going by appearance only. My mistake. I also have a 40 watt for areas with a heavy trace or heat sink. The desoldering iron is a 45 watt. I think I have the same one Athan posted.
And yes, so far even at my age my hand is rock steady....... Its my eyes that are getting worse. I have to carry my headpiece magnifier with me for almost everything now. My next investment is going to be a PC microscope.
Posted: Sun Dec 27, 2009 1:53 am    Post subject:
Here's the 40 watt I have:
http://www.radioshack.com/product/index.jsp?productId=2062738
They are actually both very light and well balanced which helps for a steady hand.
And believe me as far as lasting ability, I cant even remember how long ago I bought my main iron but I know its at least 6 or 8 years. And there are very few on here that use their iron more then I do..... Laughing
Posted: Sun Dec 27, 2009 2:16 am    Post subject:
The Rat Shack irons work well but the chords are too stiff
Posted: Sun Dec 27, 2009 2:39 am    Post subject:
Really? You think so?
Mine have just regular lamp cord and seem very flexible. Like speaker wire.
Maybe its that cold chill up there in winter wonder land..... Laughing
Posted: Sun Dec 27, 2009 11:36 am    Post subject:
I have two, a ratshack and a pro one The pro one has a cord like a thick bootlace (like a limp noodle) and it's as if there's nothing attached to the iron and if you put it down, it stays where you put it. The RS cord is like a spring and if you have to put it down, it develops a mind of it's own. The RS works well but I really hate the cord.
paw
Posted: Mon Dec 28, 2009 3:52 am    Post subject:
What about this one
Stahl Tools STSSVT Variable Temperature Soldering Station
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=374-100
Aubrey
CRT_Ben
Posted: Mon Dec 28, 2009 3:55 am    Post subject:
paw wrote:
What about this one
I bought that! Haven't had a chance to use it yet as my soldering is rather infrequent, but it looks like you can't go wrong for the money. I also bought the additional tips: http://www.parts-express.com/pe/showdetl.cfm?&DID=7&Partnumber=374-102
